VAF Forums
-   -   Stick grip problem (https://vansairforce.net/community/showthread.php?t=145226)
bob888 12-28-2016 08:22 PM
Stick grip problem
I have a problem with the stick hitting the lower instrument panel with two different versions of Tosten grips; this despite cutting nearly 1.5 inches from the bottom end of the stick (which resulted in contact with the seat structure in the full up position).
Bottom line: Does anyone have experience with another brand of stick grip that will work in the RV 10 without a significant modification of the stick?
Jesse 12-28-2016 08:28 PM
The infinity grips work well.
CharlieWaffles 12-28-2016 08:28 PM
Have you mounted the control surfaces and rigged them? They will greatly reduce the travel of the stick.
bob888 12-29-2016 06:29 AM
Thanks Jesse. Yes, all rigging correct.
