VAF Forums
-   -   Prop vibration solved. (https://vansairforce.net/community/showthread.php?t=145195)
Kahuna 01-05-2017 12:29 PM
Les is the man.
http://www.mstewart.net/super8/propclock/index.htm
You will find some actual data in there.
Strasnuts 02-28-2017 05:27 PM
I just did this and it worked for me!
My friend Scott Schmidt sent me this link when he noticed it here. He knew I had tried a few things to make my RV10 run smoother. I initially dynamically balanced the prop. That didn't change it much and it was surprisingly well balanced to begin with. I then called Lord mounts and tried some different mounts on the diagonal that they suggested. That didn't seem to work either. So I left it as is and put up with the rumble. I have an IO-540-N1A5 which has a thicker crank and heavier counterweights. I thought it was just an engine/plane/prop combo that had a shake and that was that. I noticed after flying other RV10's that mine had a worse shake. Scott Schmidt's and Tim Olson's RV both felt smoother than mine. After Scott sent me this link I started doing some research. I read all the prior posts and then called Les at Hartzell. I left a message thinking he may not call back. He has left his prior position and is now working for Hartzell and the NTSB on accident investigations. He returned my call and we chatted for a bit. We decided the best plan of action was to re-clock the prop by changing out the bushings on the prop flange. I was going to rent the tool or make one but after looking at them I decided to make some spacers and use a bolt and nut combo to push out the bushings. The same tools worked to pull them back into place at the new location. My prop was set at #1 TDC pointing to 1 and 7 looking forward from inside the cockpit so I had to move the bushings one hole over to make the prop 9 and 3. I changed four bushing so the weight would be balanced on the flange. I finally finished my condition inspection and flew the plane. What a difference! I can easily tell this did the trick on mine. Before I changed this the rich setting on takeoff and climbout would be the worse for vibration. Mixture set to the rich side in cruise with the prop at 2400 was bad too. I would climb to cruise altitude and run LOP which would smooth out the plane a bit. Now all settings are smooth. Made a huge difference on my RV10.
rsjanko 09-24-2017 07:28 PM
Re-clocking worked for me
Thanks to all who posted on the subject of prop vibration! Re clocking worked for me. The plane is smooth at all RPMs. Since my crankshaft had five drive bushings it was only necessary to move the shorter one one hole CCW to re-clock the prop since it is the short bushing that determines the position of a Hartzell prop. Note: All crankshaft holes are the same size for the bushings, there is one larger hole on the starter ring gear support (flywheel) that indexes it (its position is not changed). The prop's position is determined by the short bushing on a Hartzell prop.
Bill.Peyton 11-26-2017 07:25 PM
I will add one additional RV-10 to the re-clocking success story.
After balancing my prop to .01 IPS, it still had a slight vibration I could feel in my seat. It has been there since day one 750 hours ago. After reading this thread I decided to try it myself. I ordered two new bushings from Air Power Inc., a 79024-S and a 72155-S for a total cost of $78. I have the D4A5 with the BA 2 blade prop. I clocked the prop to 9 and 3 o'clock with #1 at TDC. It again balanced out to .01 IPS @2400 RPM.
Night and day difference. That pesky vibration in the seat is gone.
Lenny Iszak 11-26-2017 08:13 PM
didn't work for me.
I have the same D4A5 engine from Van's with the BA 2 blade prop, and had to get the same bushings 79024-S and 72155-S.
My half order vibrations in cruise doubled up after the reclock and rebalance. Went from .144 IPS to .281 IPS on the half order vibrations. It was real smooth at full power, but I couldn't stand the floor thumping at cruise (2360) rpm. I ended up clocking it back to original.
Bill, did you grab a spectral graph of your balance? I'm real curious why it didn't work out for me.
Bill.Peyton 11-27-2017 07:33 AM
Lenny,
I did notice that the prop was the smoothest at higher RPMs. It is still smoother than it used to be at 2300 prior to reclocking it, but definitely the least amount of vibration is at 2600+. Overall, it is far better @9-3 then it was @7-1.
The Dynavibe I am using only captures 1st order acceleration, so I do not have the 1/2 order data.
7DeltaLima 11-30-2017 08:31 AM
Hello all,
I have a RV10 with IO-540D4A5, two bladed Hartzell HC-C2YR-1BFP/F8068D.... Standard stuff from Vans..
I have been trying to isolate vibration so this seems the next step for me. I commute most days for about an hour and it's starting to be a pet peeve so I want prepare to give reclocking the prop a try. After that, I'll get Vic to balance the prop.
Questions:
Only see reference to the "special tool" on the first post. How has everyone else dealt with not having the tool?
I see two spacers .... 79024-S and a 72155-S .... that looks like I need to have on hand as well.
Anything else that I need to have on hand other than an extra hand? Appreciate this information!
Doug
Bill.Peyton 11-30-2017 08:43 AM
I ordered the bushings from air power. The Lycoming tool is not necessary, a box end wrench several long bolts and washers, and a socket is all that?s needed to fashion your own removal tool to remove and install the bushings. Looking at the prop from in front of the plane, the prop is clocked clockwise, counter to its rotation, so that the blades are at 9 and 3 o?clock when #1 is at tdc. The prop hub o ring should also be replaced.
flysrv10 10-09-2019 06:49 AM
I Have an IO540-D4A5 and HC-C2YR-1BFP/F8068D prop and have been chasing airframe vibration for a while. Finally after having tried prop balance, baffle replacement, engine mount replacement, ignition timing and checking all areas of the cowl for interference, I re-indexed the prop and the difference is day and night. It was a painless process done by CopaAir in Florida and took 3 hrs to complete. I did not have to buy any new prop flange bushings and borrow or rent tools to perform the work. If you are having airframe vibration, I highly recommend re-indexing after you have tried all other low hanging fruits. PM me if you need specific information.
majuro15 11-29-2019 07:59 AM
I'm having issue with airframe vibration on my newly flying 10 with an Aero Sport 540 and the 375HRT WW prop. I dynamically balanced it from .6 down to .04 but still feel the vibrations while flying at all RPMs. Seems reclocking is another trick to try, as a few folks have recommended it. I don't have to move bushing or anything, but how do folks determine how much to reclock? For reference, I had to add 60 grams to balance the prop. When the engine stops, the same blade is always at 6 oclock, putting the weights at 12 oclock. Should I reclock it by a certain rotation? 45* or 90*?
