Worn rudder cable sleeves
Question for those who work rudder a lot. How are your plastic sleeves holding? If the cable chews through the sleeve is there a way to replace it or the whole cable need to be changed? I turn the sleeves within the clamp every year but the wear is getting deep at 3,000 hours. Any ideas how to refurbish the plastic without replacing the cable?
Vlad,
Fly less.......:rolleyes: I did not build my plane and you did...how was the plastic sleeve originally installed? From my experience, the plastic tubing is pretty stiff and could be slit and popped over the cable. Seems stiff enough to hold it's shape. Sorry, but I only have a 1/3rd of your TT....but you give me things to look for on CI's. Merry Christmas Vlad. PS...I enjoy your picture laden Russian slanted posts...keep them coming. Hangar door is open if you visit Cousin Don again. |
Cable Sleeves
Vlad,
If you rotate the sleeves 90 degrees, you can probably get another 3000 hours out of them! How are the nylon bulkhead bushings holding up? Skylor |
I lubricate mine with multi-purpose spray lubricant with teflon made by Dupont This stuff is great because it goes on very thin to get into tight places and then turns to a waxy lube that will not sling off and protects against corrosion also. Very cheap also, found at stores on line or Lowes, Fleet farm, and other hardware stores. Test it yourself and you will notice the difference from other lubes...
I learned about it on a motorcycle site and they were discussing the best lubricants to use on their chain.:) ![]() |
Don't have my instructions handy, but how did we put them n in the first place, Vlad? I don't think the cables come from vans with the sleeve already on. It's been 10 years since I would have done it though so I'm not sure. ???
| All times are GMT -6. The time now is 02:44 PM. |
