Failed eye test for F-601R
The parts index for the 9A says there is a part to be fabricated
F-601R on drawing 17A. Can't find it. Also checked dwg 19 since it's supposed to be a firewall angle. Can anyone point me to the coordinates of this part ? Thanks. |
It just refers to the R or L versions of the 601 part. E.G. 601P x 2 or 601PR and 601PL
are theses what you are looking for?
Hi Patrick,
Pardon my ignorance. I'm not following. It's calling out a single part as material, meaning the part is to be fabricated but I can't find that part on any drawing or discussed in the manual. DWG 17A is for the longeron bend making this more confusing. There doesn't appear to be a distinct part 601 for there to be a left and right version. Still cannot find that part. Thanks. |
don't think so ...
Going by the construction manuals parts index: F-601R FIREWALL ANGLE 1 17A MATERIAL AA6-063X3/4X3/4 FUSE-ALL so it can't be those parts. It should be a single part F-601R. I suspect not everyone used the parts index but I used it as a reference to make sure I didn't miss fab'ing some part. I'm doing them all at once then into alodine. So, still confused. Thanks. |
Angle
Still don't think so
You are thinking of the 601D left and right. Those are manufactured. Still no joy. I've sent a message to VANs but looks like they are out until Tuesday. Thanks. |
Angle
Funny, a search on VAF turns up no results either so you've discovered a new one. |
I just searched the PDF version of the 9/9A plans and found no reference to "601R" except for the parts list. I'm wondering if it used to be a part and the design was modified but the parts list wasn't corrected.
F-601R Mystery Part
Could it be a clip for one of the stiffeners on RV-6 that is now replaced with the joggle.
I only have RV-7 drawings, maybe a RV-6 builder can check. |
On review, I think you are correct Michael, and other advise is probably accurate. Be interesting to her Vans reply. I only referred to the Index if I lost something. Cheers
I couldn't find it. I have no mention of it in my builder's journal. I guess I'm flying around without it just fine?
safe to fly
And you are safe to keep flying without it. Cheers. Michael B. |
| All times are GMT -6. The time now is 08:57 AM. |
