A Question about Altimeter Settings
I know that air temperature impacts air density and therefore altimeter readings. However, I am curious if temperature is taken into account when an altimeter setting is provided by the FAA/airport.
Is an altimeter setting provided based upon the current observed conditions/temp or is it adjusted to the standard atmospheric temperature of 20C? I have noticed higher readings when the weather gets cold and also see the warnings in IFR training materials about how cold temps show higher than actual readings. This made me assume that altimeter settings were provided based upon standard temps and not actual. Thanks, Larry |
For IFR purposes, cold temp corrections are based off of height AAE, thus being cold at airport elevation doesn't matter.
Not sure about how the FAA does things (been a zillion years since I flew south of the 49th), but up here, when temperature gets above 15C, the density altitude gets reported in the METAR/ATIS. It can get pretty extreme sometimes - a density altitude of 6000ft for a 1000ft ASL airport isn't unheard of. As far as how the altimeter setting is corrected for temp, it shouldn't matter.... if an airport is at 1000 ASL, it will always be at 1000ASL and it's pressure altitude will be adjusted accordingly... temperature doesn't matter to the airport, but it does affect your performance values (especially when hot), and how much closer to the ground you really are (extreme cold). |
Hi Larry,
Altimeter setting is simply the station pressure adjusted based on station elevation in accordance with ISA. However, you see in a typical metar where at the end it says "...SLPXXX"? That is the station pressure adjusted to the actual temperature to give you a theoretical pressure at sea level. This video I found explains it well: https://youtu.be/UBHigKBOSS8 Happy Holidays! |
Larry |
It's way more crucial on approach for obstacle clearance because as you noted the colder it is the greater the error between your indicated altitude and your actual altitude. This is why for some approaches there's notes on cold temp corrections to apply to the published minimums if the temp is at or below what's in the notes. |
Here's how it really works:
Remember that pressure is just the weight of the air above you (per sq inch). As it gets hotter, the air expands upward; colder, the air contracts downward. So if you're at sea level, temperature doesn't matter; all the air is above you, regardless of temperature, so the pressure only varies with humidity (water vapor is lighter than nitrogen molecules). You adjust for humidity when you change the Kollsman window). But if the airport is at 5000', then when it's hot, the air has expanded, and there's more air above you than standard. This extra weight produces higher pressure, so the altimeter will think it is at, say, 4000' (lower), if the Kollsman window is set for local humidity (local sea level pressure). BUT that is not how it works. The local reporting station at the airport will give you a 'fake' altimeter setting, higher than the real sea level setting, whatever it takes to make a standard altimeter read 5000' on that day. So on a warm day at South Lake Tahoe (KTVL, elevation 6000'), you will see that the altimeter setting is higher than the SLP number (after converting millibars to inch of Hg). Your altimeter should always read the correct true altitude, when you are at the same altitude as the reporting station. |
Here's how it really works...
I just push the Barrow button on the SkyView and it sets the altimeter to the nearest ADS-B reporting station. |
Larry |
Nobody's mentioned this link yet: Cold Temperature Restricted Airports
Worthwhile read, and required knowledge if you're going to take the ATP written/practical (or at least was on my test). |
| All times are GMT -6. The time now is 01:08 PM. |
