I took my 12 up today in the frigid 49F of PHX. The engine ran rough until 122F oil temp at run up. At altitude OAT was 22F with oil temp at 166F and CHT about 175F. I don't have a thermostat in either the oil or coolant system. The heater was pretty much useless at 22F OAT, and I saw no change in CHT with cabin heat applied or secure. Just posting to add a data point.
Rich |
I had the Reiff on my RV-7A and I intend to install it on the RV-12 at the appropriate time. I couldn't be happier with it.
I usually just plug it in the night before. On the 7's last flight, the outside air temp was -20. The oil was a toasty 100. Be sure to order the heater for the sump AND the cylinders. And old sleeping bag slung over the top completes the look. Propane and kerosene heaters aimed at the plane? Not for me. |
Hello???
Sorry but looks like total madness to me.
Probably wouldn't happen in 100 uses....but would be a total loss not only to plane...also hangar (and other planes in shared hangar). |
Also, I suspect the airport manager might have something to say...
Been using a 1800 watt hair dryer for preheat for years. Easy to use and light(15 oz) to carry along with you in the plane . Even set on low it has things ready to go in about 30 minutes. [IMG]
[/IMG]Brad Stiefvater Salem SD |
Anything that makes a spark can ignite gasoline. If a hair dryer or heater has a motor with brushes, there are sparks. The on-off switch will also make a spark. So an open flame heater might not be any more dangerous than a hair dryer. Gasoline vapors are heavier than air. So the higher the ignition source is off from the floor, the safer it is. An ignition source sitting on the floor is in an area with the highest concentration of gasoline vapors.
Spend the money people!! Get the Tanis and be done with it,it works awesome.
A good word about REIFF - -
I installed the REIFF system. Think it was $220 a few years ago. I leave it plugged in all winter. If you cover the engine also, all 5 of the temp sensors are within a degree or two of each other. Can't improve on that. Very happy so far.
| All times are GMT -6. The time now is 02:13 AM. |
