Oil pan heater
Looking to buy an oil pan heater and wanted to get some thoughts from you fine folks. I seen the ones that Spruce sells and other Aviation shops but they all look like a more expensive version of this doing the same thing. Is there any reason why I shouldn't buy this from a auto part store or racing shop? I don't generally shop at the aviation isle in my autoparts store for this I'm not sure why I would pay 2x to 3x the price as the ones listed in aviation supply companies.
I installed the Reiff oil pan heaters recently and here this is why I went with them instead of the much less expensive ones I found.
I got a wolverine, google them up. Good stuff!
I have 150 watts total. My Superior cold air pan was not large enough to fit more, but it is adequate. :cool: CJ |
Don't pay the premium for "racing" parts either... I got a 300W stick on pad for 29 bucks and it worked great for several winters. I would buy another in a heartbeat. Google will show hundreds of different sizes and power available very inexpensively.
I used a 250 watt heater very similar to the one you linked. It was well under $50 from an eBay seller (I believe it was a Kat or Wolverine brand). It works very well and couldn't imagine buying the same thing for $300, even if it were a better quality. Larry |
A friend gave me this one designed for an O-360, or so I was told. Note that it has cutouts for the sump drain and even the embossed part number. I stuck it on with J-B Weld (Kwik). It works really well so far.
about 6 yrs ago i stuck 2 katz heaters on my jab block. they have worked perfect ever since. a few years before i put them on the jab i stuck one on the oilpan of my toyota. and only spot to stick it was on a curved area. the car heater is also still working and has not come loose even slightly and a lot of snow , slush etc. gets flung on it in the past 8 yrs.
Same Kat heater as Merlin
Has been perfect for 5 winters 150watts seems to be enough. Never use it unattended though except maybe for a couple minutes. Plane is in a well insulated hangar after an hour of heating at 30 deg though I get instant oil pressure and temp off the peg. Just checked it last weekend and after about a minute it's very hot.
Oil Pan heater
Amir,
I recently had my engine overhauled and removed the Wolverine oil pan heater that was on it. I installed a new one and you can have the old one for postage cost. You will need to find compatible adhesive to attach it to the oil pan. I'm sure if you contact Wolverine they can send you a tube of adhesive. PM me with your address and we will coordinate details for shipping. Oly |
| All times are GMT -6. The time now is 05:47 PM. |
