VAF Forums
-   -   Forgotten mistake - opinions needed (https://vansairforce.net/community/showthread.php?t=144682)
majuro15 12-06-2016 07:18 PM
I vaguely remember botching a rivet on the aileron a long time ago. While re-installing them after doing the bottom skins, I saw it and now need to fix it. Question is, what's the best way? It is the last rivet on the inboard side closest to the trailing edge on the top skin.
This is with an "oops" rivet just resting in the hole. It doesn't fill it up, as the hole was double dimpled.
Carl Froehlich 12-06-2016 07:21 PM
Drill out to #30. Dimple then rivet #4. No one will ever notice.
Carl
Jesse 12-06-2016 07:39 PM
Carl
What Carl said.
JonJay 12-06-2016 07:51 PM
That looks a bit big to just drill out and upsize. If you can't get a clean hole as Carl is suggesting, put a rivet on each side, observing edge and hole spacing, and fill the hole before you paint.
You won't notice that later either.
RV7AJeremy 12-06-2016 09:51 PM
Agree. I had the same thought.
majuro15 12-07-2016 05:43 AM
Yeah it's already drilled out to a #30 hence the oops river. I think I'll have to go with a river on each side and filling the hole. Good idea on that.
TFeeney 12-07-2016 06:48 AM
Having a hard time envisioning putting a "rivet on each side" of the damage so that it fixes this.
When your done a followup picture would be nice.
ppilotmike 12-07-2016 10:23 AM
He's going to drill two new holes; one on each side of the bad hole, then install a rivet in each of those holes and fill the bad hole with goop, cure and sand.
TFeeney 12-07-2016 10:33 AM
Thanks Mike - I guess my post left me open to Mr. Obvious. :p
My concern was more the rivet spacing and cleaning up the existing hole - oversized to eliminate rough edges. Wondering how it all fits in the constraints.
majuro15 12-07-2016 08:02 PM
I'll post a post repair picture. Checked with my sheet metal guys at work, and they said to flatten the dimple, drill out larger to clean the hole and put a small "backer" plate behind the rib to cap the hole and provide a surface for micro to cling to. Place a rivet on each side (essentially spacing them closer together) and let it ride.
Thanks for the suggestions!
