Retrofit Baja Squadron lights in Duckworth mount ?
Have Duckworth landing lights with Par36 lamps already installed. Wondering if the Squadron pro -R model which has a round housing of approx 5 inches could be fitted into the Par36 mount without too much modifying.
good question
I have Duckworks mounts for my -10 wings, no lights installed yet. Planning to go Baja LED when the time comes. I'll wait to hear what the experienced folks say.
I have a set of rectangular Duckworth's in my wings and was interested in converting them over to LED's.
I went to their website and it appears there are conversion kits. A phone call with a left message a couple of weeks back has gone unreturned....anyone know if they are still taking orders/in business? If not, is there an (easy) conversion out there for what I'm seeking? Thanks! |
Duckworks isn't his primary business. Be patient, he'll get to you. Maybe try to give him a call. That worked for me.
I just installed the Duckworks kit this weekend. Read carefully, be careful and it will go just fine! |
I had stock Duckworths with some HID bulbs during my initial build. Before I began flying I switched over to the Baja Squadron lights - the rectangular style. Those did take some modification of the duckworth mounting plate, but not too much. I am not sure about the circular style. But the mounting plate is easy to work with so I suspect it should be easy enough to trim as needed and place new nutplates.
I recently installed the squadron pro lights in my duckworth enclosures. I just removed the duckworth mounting plate and made a new hanger assembly for the squadrons. I used AL angle (3 different pieces) that used the existing holes/nutplates on the ribs. This allowed me to easily center the light in both axis.
Sorry, but I did not take a picture of the install. The squadrons might be too heavy to effectively be mounted in the duckwork plate. Larry |
Squadron Pro = 12 oz. and is just over 3" wide |
XL Pro vs Squadron Pro
https://www.teamaerodynamix.com/shop...ing-light-kit/ ![]() |
| All times are GMT -6. The time now is 01:23 PM. |
