Monument Valley Flyout
Some Arizona RVs are going to Monument Valley March 10. It is $80
for the room ($65 AAA) and $45 per person for the half day tour. if you want to join us, go to http://www.gouldings.com/english/index.htm to book yourself. see http://www.swaviator.com/html/issueAS99/monument.html for more info. Dave Biddle RV-6A http://www.davebiddle.com |
Do you have the nearest airport identifier? or GPS coordinates? There is no airport named "Monument Valley".
Looks like the identifier, per AirNav.com, is UT25 - it's a private strip. Sounds like a cool destination. I'll definately keep it in mind for when the airplane is flying.
I believe it is now 71V Lat/Long = N 37 degrees 1.00 min, W 110 degrees, 12.04 minutes VOR/DME fixes for 71V FMN267103 DVC218077 PGA068061 Runway 16/34: 4000 feet long. Land uphill runway 16. Hard dirt for first 4/5 of runway. Takeoff downhill runway 34, asphalt for first 1/5 of takeoff run. Elevation: 5,192 Pattern altitude: 6,200 left base for 16 Tiedown cables are available but bring ropes, or ropes and tiedown anchors. Useful frequencies: CTAF: 122.9 Multicom over the monuments: 122.75 Cedar City Radio: 122.4 Denver Center: 127.55 They can pick you up above about 8,000 ft but you will need to be above 10,000 for radar service gil in Tucson |
The link
says: U96
It's U25
Apparently it's now UT25 as listed above...
http://www.airnav.com/airport/UT25 co-ordinates above are correct, and it's on the Denver sectional... www.skyvector.com gil in Tucson |
after flight plans are closed
BYOB 'cause it's not available on the reservation.
Steve |
Too bad it's not in May!! We plan on being out that way in the last two weeks in May.
Roberta |
picture of runway
Here is a picture of the runway. It is interesting to have a rock face of a vertical cliff right at the end of the runway when you are approaching. Not a lot of room for a go-around. ![]() The twins from Las Vegas that bring in the tourists land and take off on the last 900 ft of the runway which is asphalted. |
BTW -- first pic to this forum from me. We'll see if it works. :) http://img248.imageshack.us/img248/6...4306redqo0.jpg |
| All times are GMT -6. The time now is 10:30 PM. |
