VAF Forums
-   Glass Cockpit (https://vansairforce.net/community/forumdisplay.php?f=35)
-   -   VP-X not supported on Dynon Skyview HDX (https://vansairforce.net/community/showthread.php?t=143968)
Flying Canuck 11-22-2016 12:46 PM
So, I've got my HDX1100 on order and have been waiting for Dynon to release the installation guide for it - was finally posted yesterday. Going over it a bit today and hit a very unwelcome surprise.
From the manual:
Display of, and control of, VP-X is not supported in SkyView SE or SkyView HDX (as of Software v15.0). If you intend to install and use SkyView SE or SkyView HDX, do not purchase and install a VP-X or an SV-VPX-290 software license.
I've already got my VP-X Sport, and I have the software license on order. Now, it's not going to work???? I hope this is not the case because I can't cancel the HDX order and I have designed everything around the VP-X.
Anyone have any ideas on what's going on?
Wingnut 11-22-2016 12:49 PM
Not official but
when I spoke with Dynon at The Deland Sport Aviation Showcase earlier this month, it was mentioned that the VP-X support should be expected in a coming software update. I am certainly hoping so.
Carl Froehlich 11-22-2016 01:35 PM
Why the VPX attraction?
I've mentioned a few times I'm one of those nerd engineers that never understood the value of the VPX line of products. I see it as an expensive solution looking for a problem. That said, a lot of people swear by them.
I did look at how to use the product and avoid single failure risks, but always ended up with approaches that required two VPX units. That price tag makes breakers look good. As I use the the Dynon AP module that provides automatic trim functions and the stock Show Plane flap controller that comes with the RV-10 kit, not much else left to do other than simple breakers and switches.
Carl
Nomex on for the anticipated flames.
vlittle 11-22-2016 06:32 PM
Carl
I agree with you, Carl.
Mich48041 11-22-2016 08:30 PM
I agree with you Carl, but prefer fuses.
FasGlas 11-22-2016 08:42 PM
Just a side note: Why does Dynon charge for a VPX software license when the other EFIS makers don't? Just say'n..
dynonsupport 11-22-2016 08:49 PM
Same reason other EFIS manufacturers charge for aviation and obstacle databases and Dynon doesn't ;)
BobTurner 11-22-2016 08:54 PM
Originally Posted by dynonsupport (Post 1128771)
Same reason other EFIS manufacturers charge for databases and Dynon doesn't ;)
I think you meant "...some other...". Not everyone does.
FasGlas 11-22-2016 09:03 PM
Is that an answer or avoiding an answer? I have an MGL iEFIS system, I didn't pay for a VPX license or obstacle or aviation or maps or anything. Just who gets the money for this "license"? And yes, Dynon does also charge for maps.
cdeerinck 11-22-2016 09:04 PM
Wow, I hadn't heard that! I am in the same boat as you. VP-X Pro installed, and about ready to order dual HDX's. I guess that goes on hold until I see it supported. This really just wrecked my day...
