VAF Forums
-   ADS-B (https://vansairforce.net/community/forumdisplay.php?f=113)
-   -   Navworx Faa approval suspended (https://vansairforce.net/community/showthread.php?t=143962)
RVDan 11-22-2016 09:57 AM
From FAA email
FAA logo
Press Release
For Immediate Release
Date: November 22, 2016
Contact: Lynn Lunsford
Phone: (817) 222-4455
Email: lynn.lunsford@faa.gov
You are subscribed to News updates for the Federal Aviation Administration. A new Press Release is now available. We've included a copy of the release in this email.
FORT WORTH, Texas ? The U.S. Department of Transportation?s Federal Aviation Administration today issued an emergency order suspending the authorization NavWorx Inc. uses to manufacture certain Automatic Dependent Surveillance-Broadcast (ADS-B) navigation units. Such units, when properly manufactured and operated, help to improve the safety and efficiency of aircraft operations.
The authorization, known as a Technical Standard Order Authorization (TSOA), enables suppliers to produce components for use on aircraft after proving that each component meets FAA standards. Federal regulations set forth FAA?s authority to inspect suppliers? quality systems, facilities, technical data, and products to determine whether they meet safety standards. These regulations also provide that FAA may witness any tests necessary to determine a product?s compliance.
The suspension order was issued after NavWorx declined on repeated occasions to allow FAA personnel to conduct the required inspections. The suspension is immediate and will remain in effect until NavWorx consents to the inspections and demonstrates compliance with FAA standards.
The FAA is concerned that two versions of the company?s ADS600-B units, carrying part numbers 200-0012 and 200-0013, may contain an internal Global Positioning System (GPS) chip that does not meet the FAA?s minimum performance standards for transmitting an aircraft?s accurate location.
On June 29, the FAA requested to inspect NavWorx?s facility to determine the specific GPS unit and software installed in part numbers 200-0012 and 200-0013, and if the units are marked correctly. NavWorx informed the inspector that he would not be allowed inside the company?s facility. During subsequent correspondence, NavWorx agreed to allow an Aug. 31 inspection but then denied access when FAA inspectors arrived.
NavWorx later agreed to allow inspectors into the facility on Nov. 21 but they were again denied access.
Due to the company?s unwillingness to comply with these requirements, the FAA has determined that NavWorx?s continued use of its FAA authorization is contrary to the interests of safety in air commerce. During the suspension, NavWorx may not mark or otherwise indicate that its ADS600-B units meet FAA standards.
Please do not reply to this message. See our Contact FAA page for contact information.
STAY CONNECTED:
Twitter link Facebook link LinkedIn link Youtube link Flickr Link Instagram
SUBSCRIBER SERVICES
Manage Preferences | Unsubscribe | Help
This email was sent to derdan@comcast.net using GovDelivery, on behalf of: U.S. Federal Aviation Administration ? 800 Independence Avenue, SW ? Washington, DC 20591 ? 1-866-TELL-FAA (1-866-835-5322) Powered by GovDelivery
Mike S 11-22-2016 10:11 AM
So, this looks like the problem is the internal GPS chip.
If the unit is hooked up to an approved external GPS source (GTN 650 for example), it it then compliant?
fl-mike 11-22-2016 10:38 AM
Just a tip to those who play in the TSO space:
When the FAA knocks, you open the door.
AmeriKing?
NavWorx?
rleffler 11-22-2016 10:40 AM
If you asked me yesterday, I would have said yes. I actually started running new wiring from my 650 just for this.
However, the suspension implies that the door may be shut until the FAA and Navworx settle their differences. There seems to be extreme lack of transparency on both sides at the moment.
Robertc 11-22-2016 11:06 AM
What's interesting at this point is that the FAA could publish a news release immediately, but the actual order is nowhere to be found on their web site. Now it looks like a PR battle. Little ol NavWorx probably won't be able to compete with big brother. Bob
Mel 11-22-2016 11:37 AM
Something smells fishy!
My big question would be WHY the inspection refusals?
Does NavWorx have something to hide?
Jordan1976 11-22-2016 12:02 PM
https://www.faa.gov/news/press_relea...oc&cid=102_P_R
az_gila 11-22-2016 12:14 PM
I bet the paperwork stating which version chip and software vs. serial number/part number that was factory installed is not quite up to snuff...:)
Or worse still, there is no paperwork. :eek:
GalinHdz 11-22-2016 01:36 PM
Either way it doesn't sound good at all. :(
Robertc 11-22-2016 02:45 PM
Originally Posted by Jordan1976 (Post 1128601)
That's the point. The link is to the press release, but the actual order to NavWorx isn't available.
