VAF Forums
-   Autopilots (https://vansairforce.net/community/forumdisplay.php?f=37)
-   -   Navaid Autopilot (https://vansairforce.net/community/showthread.php?t=143919)
dvalle 11-20-2016 07:40 PM
Navaid Autopilot
I have one that doesn't function to well. I recall talking to one of the autopilot vendors at Sun N Fun that stated their autopilot will work with Navaid servos. Anyone know what brand?
gasman 11-20-2016 08:05 PM
I have a NEW never used complete Navaid that will link to your gps. In the box is servo, head, wiring and instructions. $350.00 to your door.
PCHunt 11-20-2016 08:15 PM
I have one that doesn't function too well. I recall talking to one of the autopilot vendors at Sun N Fun that stated their autopilot will work with Navaid servos. Anyone know what brand?
I think you are referring to the TRIO autopilot. I have one, and like it. When I bought mine, I was replacing a single-axis Navaid with a Two-axis Trio. I was going to use the old Navaid servo. The Trio guys looked it over, and it wasn't in great shape, so in the end, I bought all new servos.
Sam Buchanan 11-20-2016 08:34 PM
The Trio devices will drive the Navaid roll servo. You will need a Trio servo for pitch control.
However, you stated your old Navaid systems wasn't very healthy which may indicate problems with your servo. The digital autopilots are so advanced beyond the Navaid that you might be better served replacing the entire device.
Steve Barnes 11-21-2016 10:41 AM
works great
Have about 1000 hours on my trio auto/navaid servo combo. Works perfect. steve
longline 01-19-2017 11:05 PM
Navaid autopilot
came with my partially built RV8. Naturally, it is dated technology, but has never been used, or powered up. Servo is installed in the wing, while the rest of it resides in a box on the shelf.
My mission statement does not require an autopilot. That said, what is the feeling of the readers about installing and using this available hardware? My Dynon D-180 is not compatible with the servo, as I understand it. The Trio probably is.
Options galore here, methinks
