VAF Forums
-   -   Hartzell Composite (https://vansairforce.net/community/showthread.php?t=143367)
stancaruthers 11-03-2016 12:59 PM
Hartzell Composite
Just ordered 2 blade Hartzell Composite 74" for the ~8 IO-360 Parallel Valve
Can anyone provide experienced feedback?
RV8iator 11-03-2016 01:01 PM
Besides looking really great, it's very smooth, pulls like a freight train when adding power and stops on a dime. Great for formation.
Can you tell I love mine?
Neal@F14 11-03-2016 01:16 PM
Isn't there some possible issue with clearance / interference between the back side of the blades at full course pitch, and the cooling inlet ports on an unmodified Sam James cowl on an RV-8?
http://www.vansairforce.com/communit...d.php?t=103993
stancaruthers 11-03-2016 01:32 PM
I sure hope not, because that was my first hurdle was the oil temp right after buying this SMILE MAKER:D
New baffling
New larger dual pass cooler
More clearance between #4 cyl and cooler
Please don't tell me I will go through that again.
With the 72" blended, I could hold tail up over my head and still had 10" clearance, I don't feel adding 1" will hurt me.
stancaruthers 11-03-2016 01:35 PM
So I guess the only real question should be WHAT COLOR:rolleyes:
Neal@F14 11-03-2016 01:46 PM
You won't have any ground clearance problems with a 74" prop. My friend's RV-8 with metal 74" Hartzell has tons of ground clearance. If you ever get nosed over that far on the ground, you've then got much bigger problems on your hand than just a prop strike!
BillL 11-03-2016 06:29 PM
Hey Stan - the prop will "pull" better than the BA. I have a data sheet showing 100 lbs more thrust. 800 std.
What cowl do you have on that 8? If it is the Vans cowl, you should be fine, but check it. I assume you did not get the extended hub?
RV8iator 11-03-2016 06:41 PM
The standard Vans cowl needs the G hub and the Sam James needs an extension I believe.
stancaruthers 11-04-2016 06:23 AM
I'm still green at this stuff, I don't Sam Hill about Sam or who Sam was, but my plane kit was purchased in 2007 and first flown 2010 and the prop I ordered is from Van's
G2YR/N7605W-2X 74" Extended Hub composite 2 blade.....Requires D-4798-P Hartzell Polished Spinner
If I screwed up please yell loud NOW.
DanH 11-04-2016 06:59 AM
You have a standard Vans cowl. No problem.
