VAF Forums
-   -   Downdraft paint booth (https://vansairforce.net/community/showthread.php?t=143262)
MJarreau 10-31-2016 07:27 PM
What about side 2?
All of this makes good sense to me but I'm a little slow....
After painting/priming side one, do the parts get flipped to allow for the opposite side to be painted/primed? Are they allowed to dry and then flipped and painted/primed?
leok 10-31-2016 07:32 PM
Yes and yes
For external skins I only primed the internal side. I also chose to not prime the exposed side of the floor panels since they will be covered with carpet.
DaleB 10-31-2016 08:47 PM
I used mine with both Stewart systems waterborne primer and Shopline epoxy primer. Both of them dried in only a couple of minutes with the downdraft, quickly enough that I could flip them over and paint both sides
BillL 11-01-2016 05:24 AM
Originally Posted by leok (Post 1123062)
Quote: They are exhausf fans. I suggest intrinsically safe or squirrel cage. If you use box fans, use them to blow so volitile fumes are not passing through them.
I should have mentioned, I used Stewart Systems water based primer exclusively. No worries on flammability.
Without the fans on, overspray will come back up through the mesh contaminating the shop.
And will blow up trash from the box back onto your pretty paint. at least mine did
PilotjohnS 11-01-2016 10:21 AM
Never thought of that
I was going to flip the fan around for cure and blow clean air up thru filter. But you are right, all that trash comes back. It seems primer dries so fast it probably is not worth the trouble. Thanks for the insight.
az_gila 11-01-2016 11:14 AM
Same with the AKZO primer. It dries pretty quickly but takes a while to actually cure.
If you are careful, gently flipping the parts over after 5 minutes or so is easy and lets you prime both sides with one load of the paint gun.
BigD'sRV14 11-01-2016 07:34 PM
Small parts paint booth
Thanks all for great ideas. Will put one together soon
