Winter battery
What are people using for cold weather batteries?
I'm looking for feedback from those who fly in winter from unheated hangars or tiedown, and start at -10c or lower. The engine will be an IO-320. Even though I may be able to warm the engine sometimes I'll be at remote fields occasionally where warm up may not be an option. I ask because I've seen all the positive feedback about the pc680 but find it difficult to believe with a CCA of only 170 it can start a cold soaked IO-320. Thanks to all the cold weather warriors. Michael B. |
Preheat
Helps a lot. My plane is hangared in the Chicago area. Sometimes it's pretty cold in the hangar so I use a 150watt stick on sump heater for an hour or so and the pc680 has started it easily every time. Am continually impressed by the battery; five years flying plus two years while I was building and still going strong. Sump heater is a Kat model from Amazon.
another option
much as the 680 is used by nearly everyone, I wanted a new battery, and more crank than the Concorde RG-25.
the PC925 drops right in, with room to spare, mounted on it's side. about twice the crank of the smaller one, and same weight as the concorde, so no need to redo your w&B..... like all those other 680 guys! ;-) ....mine cranks pretty well down to freezing, don't fly when colder. |
Battery Tender Jr. works for me. If you have power.
I use a Reiff preheat system with a PC680 in an unheated hangar. Yes, it gets COLD here in the dead of winter. Starting has never been a problem .... not once.
I have Powersonic battery (same specs at the PC680). Last winter I was outside on the ramp and never had a problem starting (attempts were down to about 30*). I use an oil pan heater to bring up the oil and engine temps, but it often is not doing much to warm the battery.
Larry |
There are MANY different kinds of pre-heaters available, ranging from the cadillac of them all, the all-electric Reiff sump and cylinder band heaters, to the very most basic "put a fire under the engine" techniques. If you're thinking you're going to operate away from electrical power, that's still no excuse not to pre-heat the engine. We live in the age of very power-dense battery packs. It doesn't take much forethought to come up with a means of producing heat, and a means of circulating that heat into the engine bay. For instance, a hangar neighbor uses a pair of the piezo-electric ignition propane torches blowing into a galvanized "chimney" that routes the heat into the engine bay. Beneath this is a 12VDC fan, powered by a battery pack about the size of two cigarette packs. This works a charm. The other key item is an insulated engine cover. Talk to John at Aero Covers in Orillia - he has covers made using Thinsulate so they are not so bulky and heavy. A good engine cover will keep an engine warm for several hours, and will significantly reduce the Btu input required to get an engine up to temperature when pre-heating. Lastly, the PC680 has proven itself to be a pretty darned good battery. Its CCA rating seems to be very conservative. Be very cautious in following any advice about battery tenders etc (and read the threads here on Odyssey battery failures). Some folks have had very poor results with battery tenders and similar always-on-chargers. The joy of the Odyssey is that it holds a charge very well. The PC680 in our "daily flyer" was installed quite some time ago (2008?) and has NEVER had an external charger connected to it. It also has never shown any hesitation to crank, even at -20C OAT's (my personal safety limit for flying). But of course, at -20C, you can bet your insulated booties that I'm preheating very thoroughly! :D |
thanks
ok, I've got it. Cold soak start bad. PC 680 good. I'll still look at the other options being mentioned.
Greatly appreciate all the insight. I suspect the comment about the CCA being conservative must be somewhat true because an IO-320, even with low compression, cranking at -20c is very impressive. And thanks for the creative insights. I'll try to avoid setting a slow smouldering fire under the cowl in remote locations. Cheers. Michael B. |
| All times are GMT -6. The time now is 05:47 PM. |
