I've been trying to get up to speed on the actual argument of this AD and having a ADS600-EXP P/N xxxx 8013 that's specifically named in the AD, I have a horse in this race. Asking all who have this model installed to go back and take a look at the FAA compliance report data on your original install. Looks like page 5 has the meat on it as to accuracy and SIL and SDA which is all the talk of this AD. First of all the report was 100% compliance as per the FAA. But I was interested in just what the accuracy was /is.
Of all the arguments in this AD my ADSB was reporting well within the requirement of TSO that being .05nm or 304 ft called NACp !! it actually was (better than TSO ) under 98.5 feet 100% of the sample both times. 2455 data points on one test and 1780 points on the other it was 100% under the bracket of < 30meters!!!!! ie 100% compliant!! The SIL level was shown as reporting 2455 data points and 1780 points respectively ( on the two test) at < 1x10-7 which is at a level of SIL=3 interesting to note none at lower levels. ie 100% compliant!! The SDA was reported again both test at a level 2 100% of the time ie 100 % compliant!! By Performance Std set in the TSO it appears to me to meets all Performance Standards of the TSO and that are measured by the FAA . So whats this all about concerning the 600 EXP model. I have no info on the other models. I would like to see a plot of others data concerning the questionable parameters but it will take someone smarter that me to plot that out correctly. I will volunteer my data if any takers. Its already public knowledge!! At any rate go back and see what your 600EXP was reporting out at I bet you find it is 100% compliant. |
That report has no idea what the pedigree of your position source or the SDA of the device actually is.... |
So how or who would be able to measure those values ie SIL and SDA if it's not a measurable value? Assume the horiz boundry numbers are actually the measured performance they are talking about. Then I'm confused on how an installation can demonstrate " MEETS PERFORMANCE" without being TSO d via a pedigree from the mfg.
Manufacturer.... they would have to ensure their equipment meets TSO... it doesn't have to be certified, but proper tests need to be done to ensure it meets TSO.... and manufacturer pencil-whipping it is a no-no in FAA's eyes.
Source Integrity Level (SIL) indicates the probability of the reported horizontal position exceeding the containment radius defined by the NIC on a per sample or per hour basis, as defined in TSO-C166b and TSO-C154c. System Design Assurance (SDA) indicates the probability of an aircraft malfunction causing false or misleading information to be transmitted, as defined in TSO-C166b and TSO-C154c. I think the above are actually calculations based on some measurements rather than a measured value, after all they are just probabilities. :) |
FAA Emergency order suspends -012, -013
Just in directly from the FAA
Interesting - doesn't mention the -EXP units - which if I understand correctly contain the same GPS hardware as the -012 and -013 units. |
Thanks - I was trying to figure out how to do that!
| All times are GMT -6. The time now is 06:14 AM. |
