Any flying RV-10's near Melbourne, Australia?
Hi All,
I'm looking into the possibility of building my first aircraft. I've done quite a lot of research and given my mission I am quite heavily leaning towards the RV-10. The only thing is I've never seen one up close. I'm hoping to find someone near Melbourne that wouldn't mind showing me their aircraft and wouldn't mind me picking their brain for a little while. I'm based in the Sunbury area. Thanks in advance. Andrew |
Hi Andrew,
There are 2 x RV-10's based at YBSS, (that I know of) http://www.bmaua.com.au/ybss.html Andrew Long and Andrew McIntosh (a lot of Andrews in Melbourne) However,if you are able to get to Narromine this weekend, OZKOSH will be on from the 7th-9th October. http://ozkosh.com.au/ There will be quite a few RV-10's attending. If you visit Brisbane anytime,give me a call,happy to show you around. (zero437 852 four four four) Cheers, |
South
Hi Andrew,
If you want to see a -10 slow-build in progress, hop a flight down to Hobart sometime and I'll pick you up from the airport (10 mins away). Good luck with your decision... Regards, Adrian |
Thanks for the help guys. I'll try to get in touch with one of the Andrew's. YBSS is nice and close.
| All times are GMT -6. The time now is 04:35 PM. |
