New Cylinders....which ones?
About to pull the pin on 4 new cylinders for my narrow deck O-320.
I had my mind made up about a month ago on which ones to buy, and now I'm waffling. I won't tell you now which ones I had decided on, but will tell when this thread peters out.... I don't fly it alot, 25hrs/year, but it is in a dry climate and hangared. ECI Superior Lycoming Which of these would you choose, and why? |
had 2 engines with lyc cylinders. never had a problem in almost 5,000 hrs. :)
I chose Lycoming cylinders for my rebuild over 900 hrs ago. No regrets.
+1 for Lycoming
I have had all three brands in service among our fleet. Don't have enough hours on the Superior's to comment on them, but haven't had any issues (and this was a ten year old "new" engien that had been in desert storage). The ECI Cerminils I had for 1400 hours had a ring delamination problem, and frankly never had very good oil consumption - about 6 hours to the quart. Shortly before I replaced them, I broke in the all-Lycoming engine on our RV-3, equipped with stock Nitrided cylinders. They broke in at the two hour mark, and have run about 25 - 30 hours to the quart ever since (580 hours). So....when I needed new jugs for the Val (the one with the Cerminils), I ordered four standard Lycomings from A.E.R.O. And have been very happy with them.
Quite a turn-around for Lyclming since the late 90's when they had huge (bad) quality issues on their jugs. I thank the competition from ECI and Superior for brining Lyc back into the quality fold. Paul |
On my third full set of ECI recall cyls in 500 hours...... Never again!!
Even if they give them to me again. They did break in in just a few hours, and use less than a quart of Phillips in over 30 hours. |
My Millenium cylinders by Superior have performed flawlessly from day 1. Oil consumption is absolutely consistent at 1qt per 31 hrs. I'd get them again in a heartbeat.
ECI had just lost all credibilty. Forever!
Got bought out cheap... |
I have flown engines with new ECI, Superior and Lycoming with great results on all of them. Our RV-10 had ECI's with wonderful results for 1300+ hours.
Right now, I think I would go with Lycomings, but it's a hard choice. |
| All times are GMT -6. The time now is 02:55 PM. |
