ADSB antenna location
Where is the best location to place an adsb antenna. The fuselage is still very accessible for running wire etc.
Thanks |
An easy way that keeps separation distances good is to mount both the ADS-B receiver and antenna aft of the baggage compartment rear bulkhead. Make a simple mount for the receiver and the coax run to the antenna is less than two feet. My receiver needed only a single four conductor shielded wire to connect it to the rest of the system.
Carl |
Since the OP is in Canada I'm not sure exactly what he's asking. Are you asking about ADSB-in, for when you visit the US?
For ADSB-in I have a Skyradar mounted up front behind a side panel, with its antennas on the front fiberglass door pillars. Works great. |
I mounted my GDL-39R as Carl suggests. Keep in mind that Garmin recommends that the antenna have a minimum separation of 3.3 feet from the transponder antenna or other high-power transmitter such as a VHF radio.
I put my Transponder antenna just behind the firewall and the ADS-B antenna behind the baggage bulkhead to keep at least 3-4 ft separation.
| All times are GMT -6. The time now is 12:07 PM. |
