AFS AF-2500 Low Manifold Pressure Indication
The Problem
My Questions
Robin, I have an AF-2500 as well and I've seen the same thing happen in the past. Mine has been intermittent, though. I know you've already tried this, but for me, after I checked/tighten the connections at the analog box (usually removing the wires, resetting, and cranking down on the screws), it has always gone away. Keep us informed if you continue to have a problem!
Also, I just noticed that is your first post. Welcome to VAF! Lots of folks here to help with your new airplane.
Cheers, |
| All times are GMT -6. The time now is 04:28 PM. |
