VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   When to paint the interior?? (https://vansairforce.net/community/showthread.php?t=141968)
JHartline 09-17-2016 05:05 PM
I'm about to join the fuselage with the tail section and trying to figure out when would be the best time to paint the inside. Before or after. I'll be using a rotisserie once they are joined so rotation would be easier...so I'm leaning that way. However one could argue that accessibility might be better without the tail attached.
Suggestions?
Nova RV 09-17-2016 05:39 PM
I'm planning to attach my tail cone next week and have been thinking about this issue the last few days as well. I am leaning towards after joining so I can get it all sprayed at the same time although the dash parts will need to be painted as individual parts since it would be tough to spray the front floors with the dash in place. I want to avoid spraying the interior at different times to avoid possible color mismatch or different flow out or sheen due to temp and humidity differences between days. Another plus is that you can spray the baggage floor after installation so the pop rivets are painted along with the floor and won't be as noticeable. That said, it's tougher to manipulate the canoe around to spray it when together... That's my plan but still not totally convinced yet.
smash 09-17-2016 08:28 PM
I'm going through the same analysis right now. I already joined the tail cone, mounted the fuselage on the rotisserie and put in the baggage flooring. I wasn't sure how much I would have to mask off before painting the interior so I broke open the finish kit box and pulled out the tunnel and seat cover pieces.
I think I will paint the cover pieces first to make sure my color and paint selection are good and then move on to painting the interior. I got a quart of Stewart Systems EkoCrylic that I'm going to try out. I've already primed all my parts with their EkoPrime with good results so I thought I would try out their top coat. What could go wrong?:)
mrhorspwr 09-19-2016 10:49 PM
I am in the process of painting the cockpit. In the plans it tells you to paint before installing the rudder pedals and brakes on page 32- 08. I was worried about having to repaint everything after riveting the upper canopy deck(s) in and the paint not looking good. What i did was painted the front area behind the firewall to the first frame which will all be under the instrument panel. I also skipped ahead and built the upper forward fuselage structure behind the panel and painted it. After i rivet the upper fwd fuse stucture and the canopy deck in I will paint the entire inside of the fuselage.
JHartline 09-20-2016 05:36 AM
Good stuff
Guys, thanks for the input. I guess I need to read section 32.
Smash - Intel could hire you to run their clean rooms. Where's all the dust and metal shavings??
Still have not decided about attaching the tail before paint, but probably.
mrhorspwr 09-20-2016 02:28 PM
I would defenitly attach the tail before painting. The large bulkheads just aft of the bagage area are installed after the tail is attached. This area is very visible and wont look very good if you have to touch up because you scratched the paint while bucking all the rivets. Its all pretty easy to get to even after the tail is joined espeacially if you lay the fuse on its side.
BillL 09-20-2016 05:48 PM
Maybe not the answer you were seeking, but paint after you have selected the color scheme for the entire aircraft. Interior, upholstery, panel and possible external colors. Get samples and consider them all, then select and paint the interior when it is convenient. This will save you some possible issues later on.
vfrazier 09-23-2016 08:17 AM
I prefer to paint the interior FIRST then build the plane. Sure, you need to be more careful, vacuum up the chips once in awhile, but it sure beats removing everything to paint or trying to mask and paint around stuff.
Besides, a few scratches just aren't gonna matter to most of us... and they'll likely be hidden by upholstery, or other components anyway.
Use green masking tape to layout on top of the paint, or find some Imron type paint (if it's even still possible) that resists Sharpie ink and just go crazy, then wipe off with IPA or acetone later.
smash 10-27-2016 08:31 PM
I just painted my interior. It ended up being more involved than I thought and took way longer than I wanted... All the surfaces now have a nice glossy hard and (hopefully) durable finish. And my wife likes the color!
If you are interested, my blog has all the messy details of spraying EkoCrylic- http://www.smashsrv-14build.com/2016_10_01_archive.html
JHartline 10-29-2016 06:25 AM
That looks amazing. Mine is all masked-off and ready to paint. You should put this in the Project sticky so more folks can admire your work. Very nice!!
