Electrical Squeal
I flew my RV-7 at night for the first time last week, and as I add lights and pumps, etc, I get a progressively louder squeal/whine through my headsets. Where should I begin to debug, or shield out this noise? Thanks,
Paul Pocock |
- is your alternator internally or externally regulated? - if externally regulated, which regulator are you using? - are you using electronic noise cancelling headsets? Thanks, Vern |
It sounds like alternator noise. You could try momentarily turning off the alt field switch/breaker and see if the noise goes away. That would confirm or eliminate it as a source of the noise.
Also if the frequency of the noise changes with throttle setting, you know it's alternator related. I had the same issue. Installed a Rad Shack filter/choke kit...capacitor and transformer. Can't remember exactly where I put it, but it worked! :o
Haven't heard a hint of whine since that was done. If there is whine, there should be cheese too. |
Thanks for the input. I have the FWF 60amp alternator which is internally regulated, and use noise cancelling Lightspeed headsets.
Paul Pocock |
Paul, if you have a passive headset, see if you get the same problem. I had a similar problem with a DC headset with an aftermarket ANR. I never did fix the problem, but I'm sure a simple noise filter (capacitor) on the headset power lead would have helped. I ended up switching to a Halo headset, which has no problem. Vern |
| All times are GMT -6. The time now is 07:13 PM. |
