Degree countersink #10 screws
Having trouble finding this answer.. Which countersink do I need for the #10 screws on the rudder? Is it 82 degrees, or a 100 degree rivet countersink? On that note, what would the 130/120 countersink so be needed for?
Thanks!!! Placing an order then.
AN426 rivets have a 100 degree head.
From our bible: "e. Countersunk head rivets MS20426 (supersedes AN426 100-degree) are used on the exterior surfaces of aircraft to provide a smooth aerodynamic surface, and in other ap- plications where a smooth finish is desired. The 100-degree countersunk head has been adopted as the standard in the United States." You might be thinking of pulled rivets. |
The only "oddball" countersink on the Van's aircraft is for the CS4-4 pulled, countersunk rivets. Those are 120 degrees.
"AN" solid rivets and "AN" screws have 100? heads.
Pulled rivets typically have 120? heads. Non-aircraft screws typically have 82? heads. |
Argh. I should type what I'm thinking, instead of what my fingers were saying. "Countersunk pulled rivets" is what I meant. Previous post edited.
| All times are GMT -6. The time now is 02:27 PM. |
