VAF Forums
-   RV-14 (https://vansairforce.net/community/forumdisplay.php?f=109)
-   -   Battery Box Countersink Question (https://vansairforce.net/community/showthread.php?t=141378)
cwharris 08-29-2016 10:45 PM
Can someone explain how we are suppose to Machine Countersink the clouded holes? Even if you have an extension you cant get past the bent flange. The flange is covering the holes.
JDA_BTR 08-30-2016 04:59 AM
Before I decided to just dimple everything I figured that the right angle drill set would accept the countersink cutter. No depth stop with that but using a slow electric drill the countersink can be made.
Nova RV 08-30-2016 05:35 AM
I think if I did mine again I would try to dimple, my countersinks there at the bottom are not something I am really proud of but they are safe and get covered by the battery anyways... I tried to bent the front flange away so I could use the extension and the back side would then be forced up causing the surface to not be flat anymore and the resulting countersinks to be a little on the wobbly side.
M McGraw 08-30-2016 05:37 AM
Do it by hand
There are a few places that it is easiest to simply remove the countersink from all tools and twist it by hand. The aluminum is pretty soft it does not take that long.
mrhorspwr 08-30-2016 02:11 PM
90 deg drill
i used a 90 deg drill to do mine you can just thread the piloted countersink bit into the drill. However a good 90 deg drill is expensive. There are other areas in the kit they are helpfull for though.
Mark Browning 09-01-2016 01:31 AM
Battery Box C/sink
Thanks for the tip I used my Cleveland tools angle drill attachment it worked fine set the battery drill at a slow speed then steadily cut the sinks
really happy with the result.
