VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Bob Archer Nav Antenna install? (https://vansairforce.net/community/showthread.php?t=14129)
Rick_A 01-08-2007 09:34 AM
I have an Archer Nav antenna and I know that Bob's instructions are to mount it at the front of the wing tip and run the lighting wires along the front edge of the antenna. What I don't understand is why run the lighting wires on the antenna at all?
There's plenty of room in the wing tip to mount the nav antenna in the aft half of the tip - which would keep the antenna and lighting wires totally separate. I sent a couple of emails to Bob, but never got a reply.
N395V 01-08-2007 11:27 AM
By running the wires along the edge they effectively become part of the antenna.
By moving them 6" or so away from the antenna they will interfere with signal strength in some orientations relative to the ground station.
BlackRV7 01-08-2007 01:53 PM
Rick, since you and I are both building a 7, here is what I did also. Sorry Dan, I posted this without your permission:-) Anyway, my antenna is well aft of the the tip position/strobe lights so mine looks just like Dan's install.
http://www.rvproject.com/20040128.html
Rick_A 01-08-2007 02:56 PM
That's what I had in mind.
Dana, that just what I was thinking about doing - except on the bottom. Even on the bottom there is a good 12" or more of separation between the lighting wires and VOR antenna. I'd be interested to hear from Dan about how his installation works while flying (or anyone else that installed it like Dan).
gh6gh6 06-09-2007 09:38 AM
Archer Nav antenna
Does anyone know why the Nav antenna goes on the top of the tip? Wouldn't the antenna "see" the VOR site better from the bottom of the tip without the wing partially shielding the antenna?
Sam Buchanan 06-09-2007 11:03 AM
Not sure of the exact shape of your wingtips, but on my RV-6 the top of the tip allowed the antenna to be mounted very close to "horizontal". The antenna needs to be as close to horizontal as possible since the NAV signals are likewise horizontally polarized.
The antenna won't have any problems "seeing" the NAV signals even though it is behind the wing structure. I can't 'plain, it, only know that it works: :)
http://thervjournal.com/sportcraft.htm
az_gila 06-09-2007 02:57 PM
RF black magic
Rick... the usual standard is to keep obstructions a quarter wavelength away from an antenna.
For the VOR this is in the order of 22 inches or so. 12 inches separation is a bit too close.
Of course, all of this antenna theory is black magic.... :D
Some installation might work, and other similar looking ones won't.
Given a choice, it's probably best to stick to the standard (and what the magician says .... :) ....) in this case...
gil in Tucson - preferring digital signals to RF... :)
Ironflight 06-09-2007 03:03 PM
I actually think I mounted mine on the bottom of the wing tips....but everything was upside down at one time or another, and I can't be sure....the VOR/LOC/GS work fine, in any case!
Paul
lrfrey 06-09-2007 03:13 PM
Does anyone know if Bob Archer still sells his antennas directly? I can't find an email address for him that works.
(Garmin SL-30 just arrived, I need to feed it!)
Larry
gh6gh6 06-09-2007 05:55 PM
Where to buy
Bob Archer
21818 Ocean Ave.
Torrance CA
90503
Phone 310-316-8796
bobsantenna@earthlink.net
$70 each plus $8 ship Dec 2006
