Slick Service Bulletin
Is anyone aware of Slick SB1-98A requiring inspection of the impulse coupling(s) on any 540-XXX5, IO-540-D4A5 as an example? Has anyone had a problem with the rivets on the 5th order counterweight engines?
The engines effected: The following Lycoming O-540 and IO-540 engines configured with fifth order counterweights: O-540 A1D5, B2B5, B2C5, E4B5, E4C5, G1A5, G2A5, H2A5 IO-540 AC1A5, C1B5, D4A5, K1A5, K1B5, K1E5, K1G5, K1K5, L1C5, M1C5 AEIO-540 L1B5 TIO-540 AH1A, AJ1A, W2A The 250 hour impulse coupling inspection must be performed each time the magneto accumulates either 250 hours of operation from the time of the last inspection, field overhaul, or since new or factory rebuilt. See magneto maintenance and overhaul manuals L-1037 or L-1363 for overhaul instructions. I got this info from the Slick booth at AirVenture Thanks Gerry |
SB. I have inspected mine at the 250hr interval and found the impulse coupling specs well within tolerance. You'll need the puller to get the coupling off. https://goo.gl/photos/GzakX4AQLPjf7cfEA https://goo.gl/photos/Ucq6h5UVu9NzZbjQA |
The standard Vans setup for at least a few years now uses Retard Mags, so it may be only a small set of 10s with Impulse mags that need to do this SB.
I would not ignore if you have impulse couplings on these -5 engines
Slick service bulletin
Anyone have a copy of the slick service bulletin Slick SB1-98A?
I see a 98B but no 98A. |
| All times are GMT -6. The time now is 11:48 AM. |
