VAF Forums
-   -   Firewall Passthrough (https://vansairforce.net/community/showthread.php?t=140476)
jwilbur 08-17-2016 01:39 PM
Originally Posted by AviatorJ (Post 1104103)
Good deal, I actually made some solid progress on everything last night. Going to order another 3/4 inch pass-though for alt air/ and heater cables. Also need to order some Stainless Steel pull rivets to attach these passthroughs. Tried to use screws but the backside is really close to some brackets so pull rivets will work best.
Yep. I used CCP-32 rivets.
AviatorJ 08-17-2016 02:21 PM
Oh I ordered CCPQ-43 because I match drilled to 1/8th.
Two questions that I thought of, 1) can I put the engine mount on top of this sandwiched layer or should I cut out the spaces once I get to that point.
2) I used the 3M 2000+ as an adhesive, for the edges and seams how thick does it have to be, and is there an issue if it's too thick? I'm not the best chaulker in the business and it gets pretty messy....
jwilbur 08-17-2016 02:31 PM
Correction. I used CCP-43 rivets. The Q rivet is probably a better choice, though.
I'll let someone else answer your other questions. I didn't do the sandwich thing.
