air gizmo dock question
When the garmin handheld (296/396/496) is in the airgizmo dock the antenna has to be down. But if the antenna is down, you can't plug in the plug. Do you have to somehow take the antenna off of it and how? What am I missing? Thanks, Don
Rotate the antenna about 45 degrees to the upper left, viewing from the back, and it comes off.
| All times are GMT -6. The time now is 09:15 PM. |
