VAF Forums
-   -   axle extension for RV-10 (https://vansairforce.net/community/showthread.php?t=139066)
falcon900guy 06-19-2016 07:41 AM
I'm fitting the wheel pants currently and remember some people saying they put another axel extension on RV10 with Matco wheels. What did use and what is the purpose? Will Vans extension work on Matco wheels?
Bill.Peyton 06-19-2016 08:11 AM
The Vans supplied extensions will break. Here is what everyone is using. http://www.cleavelandtool.com/RV10-W.../#.V2anhZA8KrV
Also, you might check out the Matco front axle kit....
TimO 06-19-2016 09:02 PM
Definitely don't use the stock extension. It would surprise you if you knew how many people had them break. One person recently contacted me (I designed the one Cleaveland now sells), and told me they broke their 4th one on that plane....and it was time to switch. It's just a plainly inadequate design if you go per plans.
falcon900guy 06-20-2016 02:21 PM
Thank everyone who gave insight on the axle extension. Looks like a change when I get home on extensions!
Kenny
Carl Froehlich 06-20-2016 04:24 PM
As option you can get wheel pants from James Aircraft. They are not as wide.
Carl
