Slow or Quick Build RV-10 Body?
Hi,
I have the RV10 emp done...Soon I am going to build the body...I wanted to go QB Fuselage, but it is expensive and the wait time could be long. I may have to build most of the body alone... 2 Questions: 1. Has anyone built the RV10 body alone? 2. Should I go slow or quick build? Thanks! |
By body alone, do you mean without doing the wing kit first?
I built mine that way, you just order the spar box kit along with it. Very common once the technology got to the point that the wing spars no longer needed to be match drilled. In my opinion the legacy build fuselage was the most enjoyable part of the build. It is simply fun. Something satisfying on almost every page. You need to build up that enjoyment and satisfaction because one day you're going to be doing the cursed doors. I wanted to do a/c and insulation so legacy build was the only way to go for me. The wing kit is repetitive and rather boring with about a gazillion countersinks. Save the quick build money for that. |
I'm doing slow-build wings and fuse. Working on wings now. The above post is correct... millions of countersinks. I'm into it about 30 hours so far and it doesn't look like I've done anything.
But, I'd rather take the money i save on the slow build and put it toward toys (and avgas). Plus you mentioned the lead times. Maybe on my next build I'll go the faster route - but so far, I'm enjoying the process. |
It's all about money and how you value your time. Our opinions don't count.
I built 90% of my RV-10 by myself. I can't recall much that I couldn't perform the task by myself on the fuselage. As Myron stated, the fuselage is the most diverse and enjoyable part of the build. If you can get in at least 20 hours a week, you most likely can have it past the quick build state by the time a quick build can ship. The wings on the other hand are the most boring repeative part of the build. If money is no object, get the quick build, |
Maybe another approach?
I'm getting ready to build a slow build kit to quick build status at Synergy in Eugene, OR in September.
This is not the lowest cost approach nor is it necessarily the quickest. I could order a QB fuselage, but as you know they are 3-4 months out (published lead time) but in reality probably somewhat more. For me, the reasons are multiple. One - I had the most fun I have had in years building the empennage and tail cone at Synergy back in May. Two - the quality of the build exceeded anything I imagined I could do. The folks at Synergy held me to high standards and we achieved that. I expect the fuselage will be similar - and exceed what the Filipinos achieve - which is pretty good. Three - I would like to install floor insulation, which you cannot order as an option on a QB. Four - my spouse is actually the one who pushed me in this direction. She helped for a couple of days and observed how much fun I was having. She then encouraged me to return to build the fuselage at Synergy. So how could I refuse? As an engineer with a Master's in Business - she constantly reminds me of the adage - Quality, Cost, Speed - pick any two. I'm all about the quality, she is all about getting this done before I'm too old to fly it. So, it's going to cost a bit more. Everyone has a different situation and motivation. I highly recommend Synergy if you can afford it! |
Out of curiousity, what's the cost difference between a quickbuild fuse (or wings) and synergy air builder assistance? I'm assuming you're paying for an equal or greater level of completion at synergy, but it's tailored to your preferences. |
Yes, I went to SynergyAir and did the empennage build. They are good but you have to watch your plane as they help. You build a lot of the plane and they assist. Doing the fuse there will be really expensive!!! The cost is way more than Van's price. Phil and Allen are awesome at building planes there. The price at Synergy to do the temp and cone is about $6000.00 (their help only) plus hotel, food, time off work, and the price of the kit.
I was told at SynergyAir that I would have to have help to build the body,so that is my question. Yes, for the wings I am going fast build. I am ordering those after the body, since they just sit around until your done. |
Not exactly sure
I am considering it to be like a vacation - so I expect it will cost something. As I said before, I found it to be tremendous fun and the quality level was very high. |
Synergy Quality is pretty good. I think I escaped with only a few funky rivets. Even those guys have issues. The nice thing is you get done faster. |
Probably not too far off...
I think your estimate is probably close.
For a QB from Van's, it would be around $16K for the kit plus $7100 for the QB (includes a $1300 center carry through/spar) plus $600 for crate plus shipping. That's just under $24K. If I'm correct on the estimating from Synergy and on the low end - $31K or so. I'll know better after September. For me, the journey is a big part of this experience. I learned a lot during the tail build, as I'm sure you did too. I need to learn a lot more. |
| All times are GMT -6. The time now is 10:53 PM. |
