Master Contactor to Starter Solenoid & Main Bus.
The plans show using a copper bar to connect the master contactor to the starter solenoid. This point is also the the main power lead to the main buss (as far as I can tell). I used some .125 copper bar for the master-to-solenoid connection, but this doesn't leave much room on the master contactor stud to add a connection to the main power circuit.
It seems to me that .063 copper bar would do the job and be a lot easier to work with. The only problems is that I can't find any place to buy it. What have other people used and where did you get it? BTW. I'm using the B&C contactor & solenoid which require a 90 degree twist to connect them - not as simple as the Van's components. |
Try wiring your main feed to the input terminal of the battery contactor. It should be the same as going from the output terminal of the master except that the stud is longer (at least on mine).
EDIT DOH, I meant to say the input of the STARTER CONTACTOR! Not the battery contactor (that would be always hot) DOUBLE DOH! Jekyll |
Model airplane store
I bought 1/16" brass strip at a model airplane store. For now, that'll do until I look up the conductivity of both brass and copper and see if they're close enough.
As far as not having enough room on the stud, one thing you can do is lengthen the copper strip enough to add another bolt to it, and then attach your bus feed wire to that. |
Whats the advantage
Rick,
The plans actually call for two parallel strips of 0.063" copper between the master and starter relays, so your 0.125" strip should be just as good. I am also using the B&C master relay, because they seem to sell high quality stuff and it's a drop-in replacement for the one Van's sells. However, I went with the Van's starter relay, because as you mentioned the B&C one has a completely different terminal arrangement. The Van's starter relay also has pretty long terminal posts on it, so I am planning to bring power from the relays to the main bus via a copper strip like in this photo from Checkoway's site. btw, you can buy 0.063" copper stock from Van's here mcb |
Copper tubing
I used a piece of copper tubing. I put it in a press between to piece of steel. 10 tons of pressure and I had a nice flat buss strip. It has been working great for 150 hours
Jim RV-6 Burlington Iowa |
New old ideas
Contactors: Master, Starter solenoid or relay. Look Van can be cheap and there is always a gold plated solution, but these contactors are as good as it gets. The ones Van sells are Cole-Hersee have been around a long long long time; these contactors have been made by them and others almost identically since who knows WWII. Like so many things electrical on light planes they are adapted from the auto/truck industry. These contactors are all car, truck, folklift, farm equip stuff. To answer my own question about why the B&C unit is better, I seriously doubt there is anything better about what B&C sells in regard to contactors. Now I have found cheaper prices than Van's but not better contactors, because they are all the same inside and made in simular shape and sizes. Yes there are different shapes and terminal arrangment, but inside is a coil, plunger (solinode) and two contacts. There is a new TYPE or design I find interesting and thought about using it, a Tyco kilovac relay. http://relays.tycoelectronics.com/datasheets/ev200.pdf It cost about $120-$150. It would be used for a master. The cool part is its huge volt opening rating, more than the standard we use, is small, about the same weight, and it only takes 1.7 watts, about 0.10-0.13 amps to hold closed. A standard master contactor takes almost an amp of current (14 watts) to hold closed and gets too hot to touch. It uses some kind of magnetic latching and is failsafe, so if it fails or power is lost it opens the contacts. Now the above is not to be confused with a true latching solenoid, which have been around for a long time as well and do not cost much more than what we currently have. The down side of these types are that can fail closed. "Latching contactors" will use power to switch and than require no power at all to hold that position, closed or open. There used in boats, large trucks and industrial equip typically. They would work in a RV and save the extra heat and current to hold it closed, but are not good choices because you can end up with it closed and unable to open under some possible concevable conditions. The problem with true latching contactors is not the case with the kilovac unit I mention above, which is held in closed position with linkage and a magnet and is ready to "spring" open at all times, requiring very little current to keep it close. The down side is cost and it really does nothing more than save an amp of current. The kilovac is made to high standards of operating conditions, vibration, G's, temps and so on. Still for 6 times or more money its not value added. I guess I'll stick to the plans. The ones Van sells have long studs and can accommodate several lugs plus a thick strap, washer and nut. |
George, thanks
for the interesting info. Since I already have the B&C parts, I will use them. The Master contactor mounts just likes Van's and has the same stud orientation. The Starter solenoid mounts the same, but the studs are oriented differently. When I bought them, I did so because I thought they were higher quality, but as you pointed out, there may not be much difference.
My real question has to do with the inter- connects. Van's shows using 2 strips of .063 copper bar. Are 2 strips really required? Would one piece of .063 do the job? I made the jumper from the master to solenoid using .125 bar (which was a challenge, but I did get it to fit), but there is not enough room on either stud for a second piece of .125 to connect to the next part of the positive side circuit. (It looks like an ANL current limiter should be the next component in the circuit) |
I went from there (left side of starter contactor) to the ANL... and there's just enough room to get all of those bars on.. so you should be OK.
Rick,
I think the reason you need 2x 0.063" strips (or 1x 0.125" strip) between the master and starter relays is to handle the zillions of amps of starting current. But the next connection downstream that you're talking about only has to handle the operating loads of the rest of the aircraft, not starting current, so it doesn't have to be as beefy. Seems like you ought to be able to determine what gauge of wire you'd need for the relay-to-current-limiter connection (based on your load analysis) then check the cross sectional area of that wire vs the area of a 0.063" copper strip, and be good to go. mcb |
| All times are GMT -6. The time now is 07:05 PM. |
