building as a business
Good evening AirForce,
I am a few days away from finishing my RV-10 empennage kit and while building, I have fallen in love with the process just as much as flying itself, and that got me thinking... Have you or have you heard of a home builder starting a Limited Liability Company building parts for those that either don't have the desire to build again or maybe bought a plane already built and are in need of a section i.e.( rudder, VS, HS) to replace or maybe they got over their heads... Just thinking out loud about ways to keep building in-between my own sections and further into the future. Thanks, Robert |
Builders assistance is a common business. There are many available. Some of which, like Rick in here....build astonishing aircraft.
http://www.2bumsaircraftinc.com/ |
Sub parts are ok.
Bear in mind the 51% rule. The builder has to show that he built at least 51% of the airplane, although it seems there are complete airplanes built for pay, albeit illegally.
Instrument panel assembly and wiring are common assistance features, as are gas tank building and other sub part manufacturing. Best, |
Larry |
No, you can't just set up a nice table and comfy chair in the back of a hangar and watch as someone builds your airplane, then sign the form saying you built it without perjuring yourself. Yes, the very fast build "two weeks to taxi" programs take advantage of the wording that you must complete 51% of the TASKS listed on the FAA checklist - so when it says "rivet a wing skin", you only have to do one, then you can let the shop do the rest. |
EDIT: I am struggling to find it. To be clear, I was not talking about "Commercial Assistance" that the FAA defines as contracting out the work to someone else. This was related to having a professional help you for compensation. The language was clear that the builder must be present at all times, but that it was OK for the work to be performed by the paid assistant. This probably fell under the Educational assistance clause. I'll keep looking. Larry |
| All times are GMT -6. The time now is 11:35 AM. |
