Tip: "double-dimpling" and others
Here's info on a techinque I call "double-dimpling". In my experience, you get a much better and tighter fit on mating multiple dimpled surfaces if you use the dimple die on both pieces after using it on each piece by itself. For details, see here:
http://brian76.mystarband.net/tools.htm#redimple tool tips, especially mods I highly recommend you do to your tubing bender: http://brian76.mystarband.net/TubingBenderMods.htm and http://brian76.mystarband.net/tools.htm#plumbing other custom & tips at http://brian76.mystarband.net/custom.htm brian |
| All times are GMT -6. The time now is 07:38 PM. |
