No cracks.
RV8A Completed: 2009 Hours: 486 Slow build wings |
RV-9A.
625 hrs and no issues. slow built wings :) doug knight |
SB-16-03-28 Report your findings.
RV-9A, 9 years, 1502 hrs TTAF, no problems noted, 30m minutes total including iphone pictures. Dan from Reno
I did the same- Took off the covers and let the iPhone do the looking. All is in order. I'm keeping the picture as a record anyway. Took 45 minutes. Would have been shorter but there was a really good Grateful Dead set playing........
So it appears that at least wing kits that have shipped prior to the SB issuance do not have the appropriate parts nor instructions incorporated yet. Whether Van's will include these parts and instructions with new kits shipped after the SB remains to be seen. ETA: I checked "The List" on Van's web site and the parts called out in the SB for the RV10/14 don't seem to be included yet. ETA: I'm speculating here a bit, but if I read the plans and the SB correctly, for the RV-10, the W-1013C-L/R, W-1013A, and W-1013B-L/R combinations get replaced by W-1013D and W-1013E? respectively, so I would expect new kits to have the -D and -E parts instead of the W-1013A, W-1013B-L/R, and include the new D, E, and W-1013F-R/L and W-1013G-R/L parts. |
RV-10
Paul, the ailerons have to come off, and the flaps have to be disconnected on the the 10. And since they are primary flight controls, they get double-checked when reinstalling. :)
Vic |
I'm waiting to see how Van's will respond to my question about providing these parts to new wing kits purchasers (I just received mine in March and I don't have the new parts in my inventory). I'm hoping they will issue these parts to be fitted as part of the initial build for post-SB kits. |
SB
You're right....
We don't normally remove the flight controls during a normal condition inspection. I think once the cuts are made we might be able to inspect them without removal in the future.
And turning the inboard aileron bolt around looks like it will make it doable without having to disconnect the flap. I can't see any reason to not turn the bolt around. Vic |
| All times are GMT -6. The time now is 11:32 AM. |
