VAF Forums
-   Safety (https://vansairforce.net/community/forumdisplay.php?f=100)
-   -   Lycoming Mandatory SB 612 IO-360-M Series (https://vansairforce.net/community/showthread.php?t=137185)
sfloridaboy 04-27-2016 08:22 AM
Lycoming put out a "Mandatory" service bulletin No. 612, dated 5 April 2016, that requires replacing dipstick P/N LW-16783-18 with PN LW-14760 as the original dipstick "incorrectly gives higher oil level indication when the oil level is actually less than 5 quarts (5 liters)."
Bill Dicus 04-27-2016 08:31 AM
SB 612
Sounds as though they might help with cost. Will post result for my IO-360 Exp M1B by Lycon...
az_gila 04-27-2016 10:31 AM
Would the dipstick reading vary between a TD and nose wheel RV due to the angle of the fuselage on the ground?
What angle does Lycoming assume the engine is at when you check it?
Caveman 04-27-2016 12:13 PM
Interesting!
My vintage 2007 Mattituck M1B clone came with an unmarked dipstick. I had to level the airplane, account for the filter volume and then add oil two quarts at a time and mark the stick at various levels myself. I'd be interested to compare my dipstick to one of the recommended ones as well as the older factory marked ones.
Joe
bnt83 04-27-2016 12:38 PM
Joe
Why on earth would you level the airplane first? If you had a tailwheel or trike (on a level floor) with properly serviced tires and struts as applicable, it would make sense to mark the dipstick.
I'm not leveling a tailwheel or trike airplane to check the oil before flight....
When I calibrated the a digital fuel gauge in a C177, I leveled the airplane on jacks. When I fabricated the fuel tank dipstick, It was on level ground with properly serviced tires & strut.
Bill Dicus 04-27-2016 12:40 PM
SB 612
Just spoke with Mark @Lycoming tech support. He was very pleasant and suggested checking with Lycon to see what they have for info on dipstick they installed. Also will check part # on the dipstick I have; may save a call. Mark did not rule out warranty coverage if I have the original part # (LW 1`6783-18). Will follow up.
JonJay 04-27-2016 12:56 PM
I was surprised to find very little difference when I did this a few years back.
rzbill 04-27-2016 07:24 PM
I saw this earlier today and took a few minutes in a hectic day to call Vans to see if they would be the "authorized Lycoming distributor" since I bought it through them. Barb had not heard of the issue yet and was appreciative of the heads up. I could not stay on the phone long enough to get a formal answer since she needed to check with others. I hope to check in with her Thursday.
I have a couple of questions yet to be answered.
1) The SB says to identify the current part. So....how do I do that? Is the part number actually embossed on it somewhere? I have not been to the plane yet to see for myself.
2) How much of a level change is this really? I have not noticed any descrepancies in level indication after the 12 oil changes I have done so far. It shows what I put in and then drops a bit when I fill the new filter after the first start. Exactly as I would expect. Far from clear to me that the current dipstick in my YIO-360-M1B is actually wrong.
Bavafa 04-27-2016 10:00 PM
That is correct, I am not at the hanger to look at it now but I have seen the part number on it, at least on the stick portion but can't recall if there is any part number on the cap portion. I will be checking mine this weekend and it would be great if VANs can provide it since I bought my engine thru them too.
RV7A Flyer 04-27-2016 10:31 PM
Yep...it's embossed on the stick. Stopped by the hangar to verify I have the one that needs replacement.
Please let us know what Van's says, as I also bought mine through Van's as part of the engine/prop combination deal.
Like others, I'm a bit stymied as to how far off the measurement could actually be...plus I always add a quart when it gets down around 5 quarts, anyway (more than 6 and it just dumps it out the breather). Oil analyses are always great, so I must be doing something right :).
