Catto Prop reTorque
I read a post last week about the Long EZ that threw it's catto prop after having slight vibration warnings prior to breakup.
I have 34 hours TT on my 7A. I starting receiving a slight vibration on the floorboard on climbout. This was odd as I never experienced any in the past 32 hours. On downwind, throttling down to ~1300/1400, I noticed a vibration once again. The next flight, this ocurred again. Usually, throttling down creates a very smooth operation with this 3 blade. Anyway, I pulled the prop today. All looked good although the torque values were off. They were all running about 30-35f lbs. They were torqued as Catto req to 45. This is my first wood/comp prop and I was surprised they were off that much. I thought by having the aluminum backplate, it would not be so sensitve to environment conditions. Is this a common? |
How long has it been since you torqued the prop? What were the wx conditions then and now? Wood props (Cattos have a wood core) are very prone to changed with changing temps/ humidity. Although, I doubt that going from 45 to 35 ft/lbs would make that much difference as to cause a vibration.
FWIW, from day 1 I've noticed a vibration when throttling down from about 1800 to 1400 RPM or so. I re-torque several times per year, and the torque is never off by very much. |
I've noticed the same vibration as Jeff mentioned. Haven't checked the torque yet but plan on doing that at the 50 hr mark. That's very soon!
Dan,
Loss of prop bolt torque equates to loss of clamp force, which can equate to slippage between the friction faces of the prop and prop drive flange. If your vibration is the result of low clamp force and slippage, you'll see the evidence when you examine the faces and the bushing holes in the back of the prop. The faces will look smeared, rubbed, fretted, even burned. The bushing holes will be elongated, not tight any more, and the prop will slide on and off them quite easily. If you didn't see any of this during your inspection, your vibe source is something else. BTW, anytime you have the prop off, clean the friction faces carefully. Anything that reduces coefficient of friction between the two surfaces is bad. That includes oil, dust, oxide films, you name it. Also be sure the propeller bolts screw in by hand or with only very light wrenching. If the bolts are dragging badly in the holes you won't get the correct clamp force. The good news is that a maple core prop allows clamp force to be much higher than traditional yellow birch or mahogany propellers. Lots of margin. |
Don't know if the post you read is the same incident, but Marc Zeitlin lost his Cato about 2 weeks ago flying Cozy MKIV. Go to: http://www.cozybuilders.org/Desert_Center/index.html for pictures and the story. The departing prop nearly took the right winglet with it when it left. The airplane has been since ferried home with some temporary duct tape repair. Previously, in this experimental business, I built a LEZ and Cozy and both had wood props. The torque must be checked monthly until the wood stabilizes. Also, if you live in desert country, the wood really dries out even after things settle down, you need to check the torque on a regular basis. There have been a number of prop departures, mostly in the west dry country. There also is quite a difference in opinion about how much torgue is appropriate. Some manufacturers say 30-34 foot pounds, others will say as high as 45. I've had a Bruce Tift prop, a couple from Fred Felix, and 2 from Performance props. They all had different torque specs, so I don't know what the answer is. I do know guys in the canard world are talking about it. I doubt the current vibration is from your prop. Once they start vibrating for that reason, it won't be long and they are gone. :) But do check it. These props have a lot of good features, but a down side is the torque must be checked more often than just at the annual condition inspection. dd |
You're correct Dave in that it was a Cozy and not a LEZ. I originally put the the prop on in May, which is the start of the humid season here. The prop may have swelled with the mosture content of the air. We just started the dry season & that would mimic the time I noticed the vibration. The vibration I'm getting is very slight but noticable due to the usual smooth operation of the 3Blade. I had not checked the torque since I first installed it on May. I'll be flying this weekend & will give a followup report. Craig Catto recommends 45 f lbs. Pierre Smith or Scott Will, What has been your experience? |
I've been flying my Catto for 3 years now, and I continue to check the torque regularly, just as I did with wood props. I have never found the torque off.
Different prop manufacturers give different torque values because of different woods. Some of the many laminate props like Warnke will stand torque values up to the maximum value of the bolts. |
Hi Dan,
Haven't checked the torque as of yet but after I fly tomorrow, I'll let you know if I feel the vibes (I think I do on climbout and a little on descent). Was planning to check at 50 hrs and that is coming up pretty quick. I safety'd the bolts with .040 wire. Did you end up getting the prop repitched? My engine is only turning 2650 max at 8000' and full throttle. Goes for paint Feb 1 or thereabouts (keeping fingers crossed). Scott |
Hi Scott, My safety wire was intact with no slippage. The prop definately shrunk. I didn't get the prop repitched. I too am getting 2650 wot. I originally thought I was pitched at 78 but was incorrect. I'm pitched to 76 as you are. I still don't have the intersection fairings on. I decided to buy them from Fairings, etc. Mine came out crappy. I'll let you know once they're on. I should be receiving them within the week. |
Prop torque
I have a three-blade ELIPPSE prop made by Craig on my Lancair; it is fiberglass over wood. I typically torque my prop bolts to 25 lb-ft. BUT, I use Belleville spring washers under the bolt heads to maintain the clamping pressure, since the prop is driven by friction, not the so-called drive lugs. Klaus has cautioned me about too much torque, since it can crush the wood fibers. Those washers are the best thing you can do for your prop, especially if you live in an area subject to temperature and/or moisture extremes. Desert climates with high heat, low moisture days can dry out the moisture in the blades, so that when the day cools, the prop has shrunken slightly. Shrunken prop, less clamping. That is where the washers shine. They will maintain the clamping force over as much as .04", depending on washer stacking. Vance Jaqua before his death wrote an informative article about his analysis of their use which I've copied below. Sorry, the graphics never came through:
Paul Lipps (an innovative prop designer referenced in a previous issue of Contact Magazine) contacted me after reading the treatise on bolt preload. He indicated that he was employing an assembly of spring washers for installation of his composite over wood propeller He solicited my comments on this approach, and suggested that this would be a good basis for some analysis and an informative article. Since I had previously of some reference to this practice, I agreed with him on both counts, and started searching out reference materials It is always a source of amazement for me, how things which are very simple on the surface, have a very complex nature when examined closely. Propeller bolts are just such an enigma. For a metal prop, things are virtually that simple. Just follow the usual bolt practice, and torque them up just short of yield, and the just keep them from backing out. For a wood (or primarily wood core composite) propeller, the "wicket" gets stickier than the proverbial tar baby. The crushing strength, and "crushing" modulus of most woods used are relatively modest, and the usual bolt torque tension loads would severely damage the wood structure. This is further aggravated by the dimensional changes of the wood as moisture is absorbed and released. PROPELLER LOADS Just how tightly do we have to secure a propeller? What are the forces and loads that are trying to take the prop off your airplane? The first thing you think of is the thrust forces that are pulling (or pushing) the plane around the sky. These loads are the least of our problems. Another, more troubling load is the gyroscopic precession as the plane direction is changed by pitch and yaw. With the lighter weight wood props, this is seldom a serious problem. However a big metal constant speed prop can react a load of as much as 600 ft lbs with a yaw rate of one radian per second. This can be a serious problem if one engages in violent aerobatics. The fabled Lomchavok uses this precession force to turn the stalled airplane end over end (and broken crankshafts have been know to occur). The big need is for the clamping force, which acts much like the clutch disk in a manual transmission automobile. Although the classic prop hub has the drive lugs, the primary drive force is still this "clutch" action. If it were not for this friction, the prop would cyclically slip back and forth in the hub. The situation is further aggravated by the large displacement four cylinder engines typically used in aircraft. With only two power pulses per turn the peak torque values are higher than the rated steady values, and are actually cyclically reversed twice each turn. Once the shrinkage has reduced the preload, the cycling can induce alternating slippage at the flange face. The resulting heat further dries the wood, and a totally charred prop hub can result. I have personally seen the result of just such a scenario. The Continental IO-240 has a small prop flange designed for metal propellers, aggravating this situation. On a flight to a local fly-in, engine roughness was noted as the destination approached. An expedited landing was initiated without problems, but as the engine was cut the propeller looseness could be visually seen. The hub of the wood prop was charred, and delaminated. A replacement was borrowed for the trip home, and the damaged prop now hangs on the wall as a visual reminder. This application normally employs a 4-inch prop extension, and an extension transitioning from the Continental hub to an S.A.E. number 2 flange was mandated for all subsequent installations. The preload on a wood propeller must be moderated to avoid a crushing failure of the wood. The crushing strength of wood varies with species and density, ranging from about 1700 psi for maple down to about 840 psi for spruce. The rather aptly named "crush plate" for most props has about 18 square inches in bearing. Most of the wood varieties selected for propellers are on the high end of this range. Staying a bit below the high end at a target value of 1000psi, this would equate to a total clamping force about just under 18,000 lbs, or about 3000 pounds force for each of the six bolts. As stated in a previous article on preloading bolts, and as a general truism, determining preload on a bolt using a torque wrench is a very inexact measure. You might at first think that this is a relatively simple treatment of the analogy to driving a force up the inclined ramp representing the pitch of the thread. Sorry! No cigar. The component of the effective ramp angle is so obscured by the other friction forces, that it is totally ignored in the usual prediction, As most of you are aware, the coefficient of friction varies widely with surface finish, and degree of lubrication, as well as the properties of the two materials in rubbing contact. The usual assumption in this case is smooth steel to steel, lightly lubricated. Lightly lubricated generally means that you wiped off any visible liquid, but did not clean with any degreaser, which is about what you would do to avoid rust. Torqueing a bolt involves at least two surfaces turning against friction. The thread , of course, and the washer face of the bolt. The thread friction has a multiplier because of the vee angle of the thread, which is a much larger driver than the lead angle of the thread. Lumping all these forces and coefficients together for a 0.3 to 0.4 at the radius "arm" at the washer face of the bolt gives us a pretty good WAG estimate. The attached table of suggested torque value for the different classes of bolts in automotive use, is probably targeting about 75 percent of the allowable yield strength in the thread roots. These would also be typical of the values used for metal props, but would vigorously crush a wood prop. con't next submission. |
| All times are GMT -6. The time now is 06:37 PM. |
