Real world performance?
I will be flying an RV-6A from TX to SC on Thursday. It is 180HP with a Hartzell blended airfoil prop. I know there are variables, but for those who are flying with this specific configuration, what cruise TAS and fuel burns are you seeing at, say, 11,000'?
Thanks in advance. |
I forgot to mention, it's carbureted.
Mines a taildragger IO360. I burn about 8.3 gph cruising 157 kts TAS running 50 deg LOP @ 8k. Not sure if its typical for a RV7 or my inexperience at LOP but I get better speed on less fuel burn at lower altitudes. :confused:
My RV6 with O-360, CS prop will cruise at 155-160 kts @ 10,000 ft burning 8 gph lean of peak. Sometimes more, sometimes less depending on load. This is at about 65% power.
Wow - the variability here is pretty interesting. I'm wondering what some of the variables might be.
Well, it turns out I got about 155ktas on about 7.5-8gph at 11k and about 165ktas on ??? At 9k. No fuel flow and only a single EGT needle, so not very easy to dial in. The ??? Is because I didn't fill up after landing, so I don't know what it burned. Thanks, all, for the help. I was hoping to make it nonstop, and maybe could have by pulling back a little, but with a faulty left tank gauge and no flow meter, I wasn't going to push it.
When I was commuting between Houston, TX and Greenville, SC with my -9 I would stop half way and top off. Except that one time when I was up at 15.5 being pushed by a 50+ knot tailwind and made it nonstop and only burned 24 gallons.
You did good. Where in SC did you drop it off? |
Just seeing this thread so already OBE but still thought I would throw my numbers out.
RV-6A/IO-360-B2B/FP 85" pitch @ 11Kft 75% power I see 175 KTAS burning 9.8 leaning to peak EGT 65% power I see 164 KTAS burning 8.9 leaning to peak EGT |
| All times are GMT -6. The time now is 12:25 PM. |
