VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   B&C Wig-Wag Alternative (https://vansairforce.net/community/showthread.php?t=13574)
BlackRV7 12-20-2006 06:39 PM
Seems I have "lost" my B&C SSF-1 (or equal) flasher. On Aeroelectric, Bob refers to this as a simple automotive flasher unit. Does anyone know of a Autozone, NAPA. etc. part number.
Have to keep at it to get the fuselage to the painter by Jan. 1!!
hgerhardt 12-20-2006 09:24 PM
strobes 'n more
http://www.strobesnmore.com/
Click on the Headlight Flasher section. I'm using that as well as one of their strobe power supplies in my RV-6.
BlackRV7 12-21-2006 05:19 AM
Thanks Bobby Hester
Thanks to Bobby Hester (on another list, oh my:-), the part, or equal, is NAPA EL-13A-2, I have also heard EFL300, EFL300BP. The flasher will handle lights up to 150 watts.
For those interested in low cost wing flasher setup, Bob's is as easy as it gets. The theory is run power to one of the three tabs on the flasher unit (20 or so bucks), then run power off the remaining two tabs, one to each wing light. Now, there is a B&C S700-2-3 switch in the system. The PDF is on Aeroelectrics website, http://aeroelectric.com/articles/WigWag/WigWag.pdf. Go to your local Grainger store (or google Carling 4x850, double throw, On-none-On) and drop $4 for the switch. Now you have a wing flasher unit that weighs nothing and costs, with tax........something like $28, with no shipping, and found locally. One of those A+ deals.
See: http://www.vansairforce.com/communit...ad.php?p=38837
pwhaley6347 12-21-2006 08:36 AM
Wig Wag Alternative
Here is one I would have bought if I had found it before I ordered the B&C unit.
http://www.periheliondesign.com/wigwagmnl.htm
vlittle 12-21-2006 10:04 AM
Here's a way to wire up a wig-wag with just single pole switches. The TAXI and LANDING switches must be OFF and the FLASH switch must be on for wig-wag operation.
The advantage of this arrangement is that there is only one switch element in series with the lamps in normal operation. This makes it a bit more reliable.
I also used inrush current limiters to protect the switches and breakers and to increase lamp life. The downside of this is that I needed to pop the cover off of the flasher and increase the internal capacitor value to 10 uF to slow the flashing rate down. This allows the lamps to come up to full brightness.
Vern Little
pwhaley6347 12-21-2006 08:39 PM
What did you use for the current limiters?
vlittle 12-21-2006 10:55 PM
They are GE CL-21 devices, available from DigiKey. I sized them for my 75W wingtip lamps.
Other lamp wattages may need different devices.
see http://www.thermometrics.com/assets/images/cl.pdf
Vern
Gsuit 01-13-2008 02:22 PM
Wig... no Wag
Anyone have this issue... Both lights work in the ON position, but in the wig-wag position one light will flash, but the other will not. This is the case for me, even if I switch connections for the lights on the flasher tabs.
I'm using a Cooper Bussman 759 automotive flasher (12v, 25amp, 3-6 bulb capable).
With a meter I can read 12v at both light tabs while one is flashing. I tried a new flasher but it does the same thing.
hgerhardt 06-25-2008 10:30 PM
The Cooper Bussman 759 appears to be a standard flasher, not a wig-wig flasher. Three terminals does not automatically make a wig-wag. You need a special wig-wag flasher.
Heinrich Gerhardt
Bruce Reynolds 06-26-2008 02:28 PM
Try this one
I have the one that is intregal with the switch, but if you already have a switch, this should work as good. Mine works great.
Bruce Reynolds
RV-6A
