VAF Forums
-   Traditional Aircraft Engines (https://vansairforce.net/community/forumdisplay.php?f=21)
-   -   IO-390 from a IO-360A1B6 (https://vansairforce.net/community/showthread.php?t=135513)
AKMac 03-09-2016 08:23 AM
Hello, long time lurker wanting to build an RV-14.
I was just wondering if anyone has built a IO-390 using an IO-360A1B6 as a core?
At nearly $40k for a IO-390, I'm wondering if I can get the costs down to something reasonable. Even if the cylinders are $4k a piece, I still would be around $21k-$25k for a total engine.
Mike H 03-09-2016 08:48 AM
Try calling Barrett. They may be the best resource for a possible conversion.
http://www.bpaengines.com/
M McGraw 03-09-2016 09:22 AM
IO-390
I bought an IO-390 through Van for well less than 40K. Lycoming offers a discount at Sun-n-Fun and OSH then an additional discount if you buy the prop at the same time. I can't remember the exact price, but it was less than an IO-360.
DanH 03-09-2016 09:37 AM
Yep. They invented the 390 by doing as you describe...580 cylinders on a 360 core.
Mike S 03-09-2016 09:45 AM
Welcome to VAF!
Mac, welcome aboard the good ship VAF:D
380mxc 03-09-2016 12:53 PM
governor location
Mac,
You may find this previous post informative.
http://www.vansairforce.com/communit...highlight=a1b6
AKMac 03-09-2016 02:00 PM
Thanks guys.
I guess the propeller governor being in the wrong location would be a no go! I will contact barrett and see what they say.
I'm just joking here, but I think it would almost be less expensive to buy some machining equipment and build my own engine. :)
F1R 03-09-2016 06:00 PM
Lycoming builds IO -390 variants with the governor in both acc case and the front locations.
The factory Lyc comes with roller lifters and cam to match.
6 Gun 03-09-2016 07:46 PM
gov
I'm running an angle valve IO-360 C1E6 with gov in front on RV6.
Bob
