VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Small Gauge Wires (https://vansairforce.net/community/showthread.php?t=13549)
jlfernan 12-19-2006 02:56 PM
Small Gauge Wires
Just received my eyeball lights from Steinaie. Pretty neat, but thost TINY wires. Looking for suggestions to make connections to say, 18awg wire. Should I just solder them and use shrink tubing, or is there a more elegant way. And I'm thinking of a local ground for them, anyone know of any ring terminals that small?
Bob Axsom 12-19-2006 03:13 PM
Solder & TF Sleeve
Check some of the reference documents for the proper gauge wire for the length of your run and the current load. 18 GA is way too large. I would solder the stranded aircraft wire of 20 or 22 GA to the pigtails from the lights, cover with thermofit sleeve then crimp red terminals on to the other end of the stranded wire for ground and power interface.
Bob Axsom
Scott Will 12-19-2006 04:21 PM
I put a Molex on them. I believe it was the .063 size and they make them for different gauge wires. They make pins and sockets that fit different gauge wires - even the tiny ones on those lights or the trim servos. Don't have the part number as I discarded the packaging but I found them at my local Fry's store.
I took the ground to the firewall ground block with a 20 or 22 ga wire.
