RV-7A flutter test - factory documentation
Hello Everybody,
I'm in the final stage of registration of my RV7A project in Poland. I was asked by local Aviation Authority to deliver a documentation (or rather confirmation) of a factory flutter test for RV7A. I found many web pages including information that such test was done by Vans but cannot find this document. Could you help? Where can I find this document? Thank you Witold |
You need to ask the Polish Aviation Authority what they mean by a "factory flutter test". Are they looking for flight test data showing no flutter tendencies at or below Vne or are they expecting results from an actual wind tunnel test with a special flexible, calibrated model used in commercial/military aviation industry to verify predicted flutter margins? My guess is Van has the first but not the second.
RV7A flutter test - factory documentation
There are 2 options for the flutter test for experimental aircrafts according to Polish Aviation Rules:
1. the test has to be done by test pilot during test phase - I would like to avoid this option, 2. the test is done by factory. Very often situation in case of aircrafts build from kit. Previously I build Jabiru and I got such certificate from Jabiru AU. So I need a certificate or just a confirmation that Vans did such test when they constructed / designed RV7A. For example here you can find such information: http://www.tsb.gc.ca/eng/rapports-re...8/a10o0018.asp "The kit manufacturer had conducted flight testing of the RV-7A prototype. No indications of flutter were encountered at a speed of 217 knots. Additional theoretical flutter analysis was done where the flutter speed was calculated to be 300 knots for the baseline design." Similar statement from Vans would more than enough for me to skip option 1. Thank you, Witold |
Just a thought...
Since RV's aren't certified, every one *can* be slightly different. Paint, building variations (even with prepunched kits), controls friction/play, etc all matter with flutter issues. While the other options may get you your paperwork done, only option one lets you know for sure that everything is ok. Not doing it means that each time you go slightly faster than your previous best, you're in flight test mode again. And it might be with a passenger. Charlie |
If one is concerned about the specific variability from a test (lets assume that test is very complete, but without build variables fully explored) then wouldn't a single test of a single article have just as much statistical invalidity due to lack of a fully instrumented plane and an unquantified excitation condition? Not preaching, just trying to understand this. I have been reading too much. |
Dear Bob,
May I ask you to call or email to Vans if you have a good contact with them? Thank you in advance, Witold Quote:
You can call them yourself, they're very friendly.
See http://www.vansaircraft.com/public/builder-support.htm for a phone number and email. And don't worry about the accent, they could understand my Polish accent without an issue :) Pozdrowienia Mirek |
Hi Mirek,
Thank you. I will contact Vans directly and discuss this issue. Pozdrawiam Witek By the way - mam w Polsce kolegę o imieniu Mirek, kt?ry jest właścicielem RV7A w okolicach Radomska. Quote:
EU
Mirek
Poland is in the EU, RV's are accepted in virtually every country in the EU some on the basis of proven satisfactory service as in the UK, or where they have been stress loaded (Germany). There are 343 flying in the UK, over 9000 worldwide. I would be my bottom dollar that these aircraft are accepted into Poland when flying from abroad. I am making this point because you may not get the information you are asking for so may have to take a different approach with your CAA. You can add to this the fact that a number of Rockets and some RV4s exceed VNE set by vans regularly with no flutter problems. |
| All times are GMT -6. The time now is 02:15 PM. |
