Tip: minor fix for Sam James Plenum
http://home.cogeco.ca/~n17hh/IMG_3427.jpg
The neoprene sleeves want to slide off the front of the nostrils even when hose clamped because of a slight angle. This was the solution, I hope. Epoxy a small diameter string to the edge. |
Nice
Havent had the sliding off problem but it did occur that it might happen...
Frank |
| All times are GMT -6. The time now is 07:22 PM. |
