Bob's Z-13 v. SD-8 Distro Diagram
I've already asked this one on the aeroelectric list but no responses so I'll shoot it out to this group....
I'm in the process of wiring up the SB005-1 (S704-1?) relay with the SD-8 volt regulator and the OVM. The SD-8 distribution diagram (Dwg 504-500 rev E, 9/29/04) seems to differ from the Z-13 diagram and I'm wondering which to follow. Dwg. 504-500 refers to the relay as SB005-1, and elsewhere, it looks like the part number is S704-1. I'm not sure if these are one in the same or not. The photo at http://www.bandc.biz/S704-1_tips.html is even different and includes an additional diode installed where the OVM-14 should be installed. Anyone have a good diagram or guidance on which drawing is correct? I'm thinking that Z-13 may be the correct drawing for the application. Jim Update: I did get a response off AeroElectric: Both are. The S704-1 and similar relays (like eggs, flour and milk) are used in a variety of recipes and each recipe may treat that ingredient in a manner that is not consistent elsewhere. When you're baking a cake, you don't take a handful of recipes from multiple sources and then attempt to resolve differences between them. When someone publishes a recipe, you need to know if it's from a credible source and if the recipe is a demonstrated pathway to success. If those conditions are satisfied, then run with it. Bob . . . |
| All times are GMT -6. The time now is 07:08 PM. |
