Baffle screw behind dipstick tube challenge
Hello,
Is there a possibility to put the baffle Philips screw behind the dipstick tube without remove it ? It is installed for good with some locktite and I would want to avoid to remove it.. Does somebody have a tricks for that ? Thank you Sylvain |
Might be possible, but could not find a way so . . .
I just did mine and with the rivets all in the baffle and that bracket found no way to install without either bending or removing the dipstick tube. I removed the tube.
My baffles are painted and maybe wrestling with it would have worked, but I chose the easy path and no scratches. |
I think you're going to have to remove the dipstick tube. (Easy though)
When you remove the tube, tape off the hole so you don't accidentally drop the screw down it. :eek: |
I used a socket head cap screw. It's just possible to install and remove it with the dipstick tube in place, if you use a ball-end driver to get it started.
Thank you
Thank you Matt. It helps.
Do you know the exact size of this screw ? Here in France with the metric system, I have some difficulties... In advance thank you Sylvain |
http://www.fastenersuperstore.com/pr...machine-screws Get a larger #3 Phillips bit to insert the screw rather than the usual #2 bit size. I found a bit holder for my 12 inch long 1/4 drive extension did the job easily with a torque wrench. |
Thank you very much Gill for your reply.
I am happy to know there is a solution without removing the dipstick. Sylvain |
| All times are GMT -6. The time now is 12:26 PM. |
