And Jerry, I appreciate your suggestion about a red plug. I'll do that. |
It should be high on the list of concerns for anyone doing modifications that add weight to outer positions on the airplane (such as tip tanks, outboard aux fuel tanks, etc.). Once flight testing (which I know you are doing, because the resultant handling is the primary purpose you are doing it) has proven that there are no negative influences, then the concern can be set aside. My concern is that a thread like this might cause people to take a casual attitude regarding polar moment of inertia influences. The are very real and are fully capable of transforming an airplane with good spin recovery in to one where there is no spin recovery. |
CG vs Polar Moment of Inertia
Test thoroughly! Skylor |
Respectfully
Please wear your parachute, while testing thoroughly from a very safe altitude. Best of luck! |
Just an idea
I'm thinking maybe there could be a way to jettison your extra weight if you were to forget. Maybe a electric solenoid or cable operated valve on the drain tube. Just a slot cut in the tube with an aluminum blade, a small return spring and a light cable or something.
I took the plane up this morning and tried everything I could think of to put it into a flat spin. (By the way, an accelerated spin is not a nose high spin. And it is one of the easiest spins to recover.) I started at 11,500 feet and recovered at 5000 feet. Tried it three times, both directions, with and without aileron input, power on and off. Bottom line... it flies great! And, yes I always wear a chute when doing aerobatics. Is Bill McLean the only one who agrees that this is a good thing? Are there no more experimental pilots out there? Jeeze! (OK, rant over. Thank you for your patience.) Out. |
You have clearly done the flight testing to validate that you still have sufficient positive stability to meet your needs. Considering that many RVs go through their entire phase one in essentially "point A to point B" flight as you described it earlier, I think you're ahead of the game. Thanks for sharing your idea and engaging in the conversation. What do you think? |
I'm wondering how you will turn the aircraft on its side to shake that shot out the little hole :D
| All times are GMT -6. The time now is 10:21 PM. |
