VAF Forums
-   -   Manual to electric flaps on an RV-4 (https://vansairforce.net/community/showthread.php?t=132987)
RFazio 12-29-2015 04:52 AM
My buddy wants to change his 4 over to electric flaps. I see vans sells two kits for this. One uses the original weldment, and the second uses a new weldment. The second is more expensive of course. Has anyone done this with these kits. They don't show very good pictures of the kits. I can't really tell how they are different. I can't see how using the original weldment would work. Any info on this would be appreciated.
Richard
RogerG 12-29-2015 05:56 AM
Richard,
The original manual weldment does have to be modified. I can't remember the details, but it seems it was outlined pretty well in the 27 years of Rvaviator. If you have the PDF of Rvaviator, you should be able to do a search.
http://vansaircraft.com/cgi-bin/stor...uct=rvator-yrs
clevtool 12-29-2015 08:45 AM
I have done it with the retrofit weldment. Keeps from having to cut and weld on original if I recall. It was straightforward and is a great improvement. I put the switch on the bulkhead just in front of the throttle for easy reach. The worst part was doing all the work between your feet. Doing it again I would make sure to have a helper to run for tools, and set up a scaffold even with the longeron and perpendicular to the fuse. to lay on. I seem to remember breaking a lot of angle drill bits for some reason.
SMRacer 12-29-2015 10:13 AM
RV8 style
Or you can do it the easy way. It is still necessary to weld the two brackets on the original lever. I had intended to connect the motor to the black bracket, but the geometry didn't work. (mainly because I didn't use the Van's motor assembly). So the additional bracket was added to insure the motor would free wheel at both full extend and full retract.
Jim
rbibb 12-29-2015 10:46 AM
Originally Posted by SMRacer (Post 1040862)
Jim
This is a much improved design (more like the RV-8 implementation) that the RV-4 design, IMO.
If I was doing this I would go this route. I did the RV-4 retrofit using the factory modified weldment and it is a it of a pain but doable. This would be easier to install as the access is much easier.
RogerG 01-28-2016 05:16 AM
Jim
Jim can you comment on what motor actuator assembly you found to work for this application? Nice easy setup. Thanks for sharing.
