VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   How many fuses needed??? (https://vansairforce.net/community/showthread.php?t=132961)
9GT 12-29-2015 07:34 PM
I used three of these from Steinair and used almost every one. Everything electrical has its own terminal/fuse. Nothing is tied together.
http://steinair.com/storedetail.cfm?productid=217
Mike D 12-29-2015 08:59 PM
Here is what I did in my 3rd panel redo on my -6a. (22 fuses used+ some spares)
version 1.0 had the 10-fuse block on the sub panel. But this was moved to the new location in version 2.0 for easier access and to make room for the EFIS.
I have a terminal strip on the sub panel with the screw type attachment as shown by wjb. But I hate dropping the screws so I won't repeat this mistake in the -10.
I like the location. By my left knee. I like that they are auto fuses and fast on connectors. I like the low profile of this block.
But it just does not look clean like I want. This is why I am looking into the Eaton/Cooper fuse blocks. They can hide all the wires behind the fuse block.
Well, off to continue the electrical layout. :)
az_gila 12-29-2015 10:22 PM
Originally Posted by wjb (Post 1040980)
I'm looking at using fuses, too, rather than breakers or VP-X equivalent.
These blocks look promising and it connects with screws with ring terminals rather than a special crimp-on connector for the fuse terminal. Lots of sizes and configuration options
http://www.ceautoelectricsupply.com/fuseholders.html
Different fuse location, but this ANL fuseholder sold at the link above looks useful.
Too late for me to change, but I think it work work better than the totally open holders -
bret 01-03-2016 06:33 PM
Hu...must be a trend, I bought three of the exact same thing a couple weeks ago.....and a lot of expensive wire......
