VAF Forums
-   Electrical Systems (https://vansairforce.net/community/forumdisplay.php?f=43)
-   -   Electrical system Cad (https://vansairforce.net/community/showthread.php?t=13252)
rlo1 12-07-2006 03:13 PM
I would like to start roughing our my electrical system on CAD. I have Visio and it probably will be OK.
Anything better out there with aircraft symbols/templates already in place????
Thank you
-Ron
Jim P 12-07-2006 03:25 PM
Visio
Ron,
Visio seems to work well for me. I was using 2003 and have upgraded to 07 and the diagrams look fairly good.
Jim
rlo1 12-07-2006 03:42 PM
visio
Did you use blocks for relays, alternators, starters etc...? or did you draw them up yourself? I did not see any shapes that looked right.
scard 12-07-2006 04:05 PM
aeroelectric publishes all of their drawings and symbols as .dwg files that are available. That is where I started.
I say symbols, because they aren't defined as blocks in their stuff. A good start anyway.
petehowell 12-07-2006 06:40 PM
Check Your E-mail
Ron, Dropped you a copy of what I did See if it might help you get started.
Let me know if you have any questions.
az_gila 12-07-2006 07:25 PM
TurboCAD
Ron ... I like TurboCAD.
It's a full drawing package, and you can by older, legal versions on e-bay for $10 or so.
It will read and write in AutoCAD format (the .dwg files) and can read the files that AeroElectric Bob has on his web site.
http://www.aeroelectric.com/PPS
Just take all of the AeroeEectric pages, and edit to suit your plane... he has done all of the symbols and most of the layout you need.
Just search e-bay for "turbocad", I think version 9.x is the current cheap one. It will do all you need, and advanced stuff you don't need such as 3D drawing/rendering.... :)
gil in Tucson
vlittle 12-07-2006 08:29 PM
If you want to use a simple yet flexible system designed for electrical design, go to the following page and follow the links for both the editor and a library (that's easy to update). There is also a complete schematic for an RV that you can modify.
Vern Little
Vx Aviation
rlo1 12-08-2006 07:00 PM
Thank you all. Pete Howell sent me an awesome file. I have owned Visio for some time and I was hoping to get something for that.
These forums are awesome.
-Ron
fstringham7a 12-08-2006 09:52 PM
Vern
Help....I have tried to install the symbols after loading up the program...unzip...try to load file (symbol) to a ExpressSCH worksheet with no luck. As you can tell I am computer challenged. Basically it says that it isn't a vaid .S file
TIA for any help
Frank @ sgu and slc wiring/fiberglassing 7A
vlittle 12-08-2006 11:00 PM
Originally Posted by fstringham7a
Vern
TIA for any help
Frank, after you've installed ExpressPCB/ExpressSCH, you can extract the symbol library to C:\Program Files\ExpressPCB\SchComponents_Custom.
If you installed ExpressPCB elsewhere, you can modify this as required.
Vern
