Single Landing Light Flasher? (not wing wag)
I have a single landing light and want to add a flasher to
the electrical system. I read somewhere that the "wing wags" will burn out if you attach them to only one light. Any single light "flashers" that are recommended??? Thanks. Bruce W. |
I put one of these on my RV-4 to flash my landing lights. Been in there for two years with no problems.
B and C Specialties Solid State Flasher Forgot to say and it should work just fine on one bulb. Just modify the schematic B and C has on their web site. |
Regards, |
Add the resistor
Bryan's power calculations are a little bit shy.... ;) If you have a 100 watt landing light bulb, a 1.2 ohm resistor should do it... needs to be about 50 Watts though (100 watts - same as the landing light, but with a 50% duty cycle, makes it 50 watts dissipated in the resistor). I would use two 2.4 ohm resistors of 25 watts each in parallel to get the 1.2 ohms... Mouser has them cheap... bottom right of this page... http://www.mouser.com/catalog/628/526.pdf gil in Tucson Grumman does this with the old fashioned red flashing quartz bulb on top of the rudder... |
Gil, Yeah, I didn't do any math, just a weak guess. http://www.angelfire.com/pa/baconbacon/page2.html Best, |
R= 144/100 = 1.44 ohms. -mike |
Mike, You were to quick! I realized my mistake and couldn't fix it as fast as you were able to correct me on it. Anyway, with the above calculator you can enter the 100W and 12 volts to come up with the resistance in the bulb quickly. Then you can do the same to figure the resistor value and wattage needed. Oops!!! The point of the original post was to suggest using a resistor and I was busily watching deal or no deal on tv. Your right that I locked in on the 100w thing and reading it as if Gil was implying the lamp had a 100 ohm filiment. This locked me up because it just didn't compute. My mistake.
Best, |
Contact Eric Jones at Perihelion http://www.periheliondesign.com/ Eric can easily modify his wig wag for 1 light. Jekyll |
Auto Equipment
Is there some reason we can't just use an auto emergency flasher? I don't know, maybe the auto manufacturers have gone to a solid state flashing system by now. It just seems to me that some of these auto systems could be used in non-critical flight systems for less cost.
Thanks for the replies
See, that's why I love posting on this site. There is no way I could have figured out the electronics math. You guys are great. I barely know an ohm from a watt. I'll take your posts to the local aeroelectric expert who will translate for me. I understand the "put a resistor on it" part, just which one. Thanks again.
Bruce W. |
| All times are GMT -6. The time now is 07:18 PM. |
